MBRF1080CT
MBRF1080CT
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    特性:150℃结温工作。 中心抽头配置。 低正向压降。 高纯度、高温环氧树脂封装,增强机械强度和防潮性。 高频工作。 保护环,增强耐用性和长期可靠性。应用:开关电源。 转换器
MBRF1080CT 数据手册
SANGDEST MICROELECTRONICS MBRF1080CT(CTR) Green Products Technical Data Data Sheet N1325, Rev. - MBRF1080CT(CTR) SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150 °C T J operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request MBRF1080CT MBRF1080CTR Mechanical Dimensions: In mm SYMBOL A A1 A2 A3 b b1 b2 b3 b4 c D E e e1 H1 L L1 L2 L3 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Θ5 MIN. 4.30 1.10 2.80 2.50 0.50 1.10 1.50 1.20 1.60 0.55 14.80 9.96 6.50 12.70 1.60 0.80 0.60 3.30 2.99 2.50 TYP. 4.50 1.30 3.00 2.70 0.60 1.20 1.60 1.30 1.70 0.60 15.00 10.16 2.55 5.10 6.70 13.20 1.80 1.00 0.80 3.50 3.19 2.70 5° 4° 10° 5° 5° MAX. 4.70 1.50 3.20 2.90 0.75 1.35 1.75 1.45 1.85 0.75 15.20 10.36 6.90 13.70 2.00 1.20 1.00 3.70 3.39 2.90 ITO-220AB • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRF1080CT(CTR) Green Products Technical Data Data Sheet N1325, Rev. - Marking Diagram: Where XXXXX is YYWWL MBR = Device Type F = Package Type 10 = Forward Current (10A) 80 = Reverse Voltage (80V) CT/CTR = Configuration SSG = SSG YY = Year WW = Week MBRF1080CT MBRF1080CTR Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AB (Pb-Free) MBRF1080CT(CTR) Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward Current Max. Peak One Cycle NonRepetitive Surge Current (per leg) Symbol VRWM Max. 80 Units V IF(AV) Condition 50% duty cycle @TC =100°C, rectangular wave form 10 A IFSM 8.3 ms, half Sine pulse 120 A • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRF1080CT(CTR) Green Products Technical Data Data Sheet N1325, Rev. - Electrical Characteristics: Characteristics Max. Forward Voltage Drop* Symbol VF1 VF2 Max. Reverse Current at DC condition (per leg) IR1 IR2 Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change RSM Isolation Voltage (t = 1.0 second, R. H. < =30%, TA = 25 °C) * CT LS dv/dt VISO Condition @ 5A, Pulse, TJ = 25 °C @ 10A, Pulse, TJ = 25 °C @ 5A, Pulse, TJ = 125 °C @ 10A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body Clip mounting, the epoxy body away from the heatsink edge by more than 0.110" along the lead direction. Clip mounting, the epoxy body is inside the heatsink. Screw mounting, the epoxy body is inside the heatsink. Max. 0.85 0.95 0.75 0.85 1.0 Units V 15 mA 300 pF 8.0 nH 10,000 4500 V/µs V V mA 3500 1500 Pulse Width < 300µs, Duty Cycle
MBRF1080CT 价格&库存
很抱歉,暂时无法提供与“MBRF1080CT”相匹配的价格&库存,您可以联系我们找货
