MBRF10100CTP
MBRF10100CTP
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    特性:可在150℃的结温下工作。 中心抽头配置。 正向压降低。 采用高纯度、高温环氧树脂封装,增强机械强度和防潮性。 可高频运行。 设有保护环,增强耐用性和长期可靠性。应用:开关电源。 转换器
MBRF10100CTP 数据手册
SANGDEST MICROELECTRONICS MBRF10100CTP Green Products Technical Data Data Sheet N0077, Rev. - MBRF10100CTP SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150 ℃ TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request OUTLINE DRAWING Mechanical Dimensions: In mm SYMBOL A A1 A2 A3 b b1 b2 b3 b4 c D E e e1 H1 L L1 L2 L3 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Θ5 MIN. 4.30 1.10 2.80 2.50 0.50 1.10 1.50 1.20 1.60 0.55 14.80 9.96 6.50 12.70 1.60 0.80 0.60 3.30 2.99 2.50 TYP. 4.50 1.30 3.00 2.70 0.60 1.20 1.60 1.30 1.70 0.60 15.00 10.16 2.55 5.10 6.70 13.20 1.80 1.00 0.80 3.50 3.19 2.70 5° 4° 10° 5° 5° MAX. 4.70 1.50 3.20 2.90 0.75 1.35 1.75 1.45 1.85 0.75 15.20 10.36 6.90 13.70 2.00 1.20 1.00 3.70 3.39 2.90 OPTION 1(HD) • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRF10100CTP Green Products Technical Data Data Sheet N0077, Rev. - OPTION 2(SR) ITO-220AB • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRF10100CTP Green Products Technical Data Data Sheet N0077, Rev. - Marking Diagram: Where XXXXX is YYWWL MBR F 10 100 CTP SSG YY WW L = Device Type = Package type = Forward Current (10A) = Reverse Voltage (100V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AB (Pb-Free) MBRF10100CTP Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Symbol VRWM Max. Average Forward IF(AV) Condition 50% duty cycle @TC =105°C, rectangular wave form Max. Peak One Cycle NonRepetitive Surge Current (per leg) IFSM 8.3 ms, half Sine pulse Max. 100 Units V 10 A 120 A • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRF10100CTP Green Products Technical Data Data Sheet N0077, Rev. - Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * Max. Reverse Current at DC condition (per leg) Max. Reverse Current (per leg) * Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change RSM Isolation Voltage (t = 1.0 second, R. H. < =30%, TA = 25 °C) * Symbol VF1 VF2 IR1 IR2 CT LS dv/dt VISO Condition @ 5A, Pulse, TJ = 25 °C @ 5A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body Clip mounting, the epoxy body away from the heatsink edge by more than 0.110" along the lead direction. Clip mounting, the epoxy body is inside the heatsink. Screw mounting, the epoxy body is inside the heatsink. Max. 0.85 0.75 Units V V 1.0 mA 15 mA 300 pF 8.0 nH 10,000 V/µs 4500 V 3500 1500 Pulse Width < 300µs, Duty Cycle
MBRF10100CTP 价格&库存
很抱歉,暂时无法提供与“MBRF10100CTP”相匹配的价格&库存,您可以联系我们找货
