MBR10200CT
MBR10200CT
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    一对共阴极
MBR10200CT 数据手册
MBR10200CT Technical Data Data Sheet N0621, Rev. A Green Products MBR10200CT SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150 °C TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm Symbol A A1 A2 b b1 c D D1 E e e1 H1 L L1 ΦP Q Θ1 Θ2 Θ3 Dimensions in millimeters Min Typical Max 4.42 4.57 4.72 1.17 1.27 1.37 2.59 2.69 2.89 0.71 0.81 0.96 1.17 1.27 1.35 0.36 0.38 0.61 14.94 15.24 15.54 8.85 9.00 9.15 10.01 10.16 10.31 2.54 5.06 6.04 6.24 6.44 12.7 13.56 13.78 3.5 3.74 3.84 4.04 2.54 2.74 2.94 7° 3° 4° TO-220AB • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR10200CT Technical Data Data Sheet N0621, Rev. A Green Products Marking Diagram: Where XXXXX is YYWWL MBR 10 200 CT SSG YY WW L = Device Type = Forward Current (10A) = Reverse Voltage (200V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package TO-220AB (Pb-Free) MBR10200CT Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current Peak One Cycle Non-Repetitive Surge Current (per leg) Symbol VRRM VRWM VR Condition - Max. 200 IF (AV) 50% duty cycle @TC =105°C, rectangular wave form IFSM 8.3 ms, half Sine pulse Units V 5(Per leg) 10(Per device) A 128 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR10200CT Technical Data Data Sheet N0621, Rev. A Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg)* Reverse Current (per leg)* Symbol VF1 VF2 Condition @ 5 A, Pulse, TJ = 25 °C @ 5 A, Pulse, TJ = 125 °C IR1 @VR = rated VR TJ = 25 °C IR2 Junction Capacitance (per leg) Series Inductance (per leg) Voltage Rate of Change * CT LS dv/dt @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Typ. 0.86 Max. 0.98 Units V 0.71 0.78 V 0.0001 1 mA 0.05 7 mA 80 150 pF 8.0 - nH - 10,000 V/μs Specification -55 to +150 -55 to +150 Units °C °C Pulse Width < 300µs, Duty Cycle
MBR10200CT 价格&库存
很抱歉,暂时无法提供与“MBR10200CT”相匹配的价格&库存,您可以联系我们找货
