SANGDEST
MICROELECTRONICS
MBRF10200CT
Technical Data
Data Sheet N0079, Rev. A
Green Products
MBRF10200CT SCHOTTKY RECTIFIER
Applications:
Switching power supply
Converters
Free-Wheeling diodes
Reverse battery protection
Features:
150°C TJ operation
Center tap configuration
Low forward voltage drop
High purity, high temperature epoxy encapsulation for
enhanced mechanical strength and moisture resistance
High frequency operation
Guard ring for enhanced ruggedness and long term reliability
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
OUTLINE DRAWING
Mechanical Dimensions: In mm / Inches
OPTION 1(CJ)
OPTION 2(HD)
Dim
Min
Max
Min
Max
A
4.35
4.65
4.30
4.70
b
0.50
0.75
0.50
0.75
b1
1.15
1.402
1.20
1.45
b2
1.55
1.802
1.60
1.85
b3
1.55
1.65
1.50
1.75
b4
1.10
1.35
1.10
1.35
C
0.50
0.75
0.55
0.75
D
14.8
15.2
14.80
15.20
E
10.06
10.26
9.96
10.36
e
2.46
2.62
F
2.85
3.15
2.80
3.20
G
6.50
6.90
6.50
6.90
L
12.70
13.70
12.70
13.70
L1
3.40
3.80
3.40
4.00
L2
2.60
3.00
Q
2.60
2.80
2.50
2.90
Q1
2.50
2.90
2.50
2.90
ØR
3.40
3.60
3.30
3.70
2.55TYP
• Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113 (86) 25-87123907 •
• FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn •
SANGDEST
MICROELECTRONICS
MBRF10200CT
Technical Data
Green Products
OPTION 3
OPTION 4
Dim
Min
Max
Min
Max
A
4.53
4.93
4.50
4.90
b
0.71
0.91
0.70
0.90
b1
1.15
1.39
1.33
1.47
C
0.36
0.53
0.45
0.60
D
15.67
16.07
15.67
16.07
E
9.96
10.36
9.96
10.36
e
2.54TYP
2.54 BSC
F
2.34
2.76
2.34
2.74
G
6.50
6.90
6.48
6.88
L
12.37
12.77
12.78
13.18
L1
2.23
2.63
3.03
3.43
Q
2.56
2.96
2.56
2.96
Q1
3.10
3.50
3.10
3.50
ØR
2.98
3.38
3.08
3.28
SANGDEST
MICROELECTRONICS
MBRF10200CT
Technical Data
Green Products
OPTION 5(SR)
ITO-220AB
SANGDEST
MICROELECTRONICS
MBRF10200CT
Technical Data
Green Products
Marking Diagram:
Where XXXXX is YYWWL
MBR
F
10
200
CT
SSG
YY
WW
L
= Device Type
= Package type
= Forward Current (10A)
= Reverse Voltage (200V)
= Configuration
= SSG
= Year
= Week
= Lot Number
Cautions:Molding resin
Epoxy resin UL:94V-0
Ordering Information:
Device
Package
ITO-220AB
(Pb-Free)
MBRF10200CT
Shipping
50pcs / tube
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
Maximum Ratings:
Characteristics
Peak Inverse Voltage
Symbol
VRWM
Condition
Max.
200
Units
V
Average Forward Current
IF(AV)
50% duty cycle @TC =105 °C
rectangular wave form
10
A
Peak One Cycle NonRepetitive Surge Current
(per leg)
IFSM
8.3 ms, half Sine pulse
128
A
SANGDEST
MICROELECTRONICS
MBRF10200CT
Technical Data
Green Products
Electrical Characteristics:
Characteristics
Forward Voltage Drop
(per leg) *
Reverse Current at DC
condition (per leg)
Reverse Current (per leg) *
Junction Capacitance
(per leg)
Typical Series Inductance
(per leg)
Max. Voltage Rate of Change
RSM Isolation Voltage
(t = 1.0 second, R. H. <
=30%,
TA = 25 °C)
Symbol
VF1
VF2
IR1
IR2
CT
LS
dv/dt
VISO
Condition
@ 5A, Pulse, TJ = 25 °C
@ 5A, Pulse, TJ = 125 °C
@VR = rated VR
TJ = 25 °C
@VR = rated VR
TJ = 125 °C
@VR = 5V, TC = 25 °C
fSIG = 1MHz
Measured lead to lead 5 mm from
package body
Clip mounting, the epoxy body
away from the heatsink edge by
more than 0.110" along the lead
direction.
Clip mounting, the epoxy body is
inside the heatsink.
Screw mounting, the epoxy body
is inside the heatsink.
Max.
0.98
0.78
Units
V
V
1.0
mA
7
mA
150
pF
8.0
nH
10,000
V/μs
4500
V
3500
1500
Pulse Width < 300µs, Duty Cycle
很抱歉,暂时无法提供与“MBRF10200CT”相匹配的价格&库存,您可以联系我们找货
