MBR1545CT
MBR1545CT
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    特性:150℃ T₂ 运行。 中心抽头配置。 低正向压降。 高纯度、高温环氧树脂封装,增强机械强度和防潮性。 高频运行。 保护环,增强耐用性和长期可靠性。应用:开关电源。 转换器
MBR1545CT 数据手册
MBR1545CT MBRB1545CT MBR1545CT-1 SANGDEST MICROELECTRONICS Technical Data Data Sheet N0736, Rev. - Green Products MBR1545CT /MBRB1545CT /MBR1545-1 SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150 °C TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request MBR1545CT TO-220AB Case styles MBRB1545CT D2PAK Mechanical Dimensions: In Inches / mm MBR1545CT-1 TO-262 TO-220AB • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • MBR1545CT MBRB1545CT MBR1545CT-1 SANGDEST MICROELECTRONICS Technical Data Data Sheet N0736, Rev. - Green Products Symbol A A1 A2 b b1 c c1 D D1 E E1 E2 e H L L1 L2 L3 e e1 e2 e3 D2PAK Dimensions in millimeters Min. Typical Max. 4.55 0 2.59 0.71 0.36 1.17 8.55 6.40 10.01 7.6 9.98 14.6 2.00 1.17 0 4.70 0.10 2.69 0.81 1.27 0.38 1.27 8.70 0.61 1.37 8.85 10.16 10.31 10.08 2.54 15.1 2.30 1.27 10.18 0.25BSC 5° 4° 4° 4.85 0.25 2.89 0.96 15.6 2.70 1.40 2.20 8° TO-262 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • MBR1545CT MBRB1545CT MBR1545CT-1 SANGDEST MICROELECTRONICS Technical Data Data Sheet N0736, Rev. - Green Products Marking Diagram: Where XXXXX is YYWWL MBR B 15 45 CT/CT-1 SSG YY WW L MBR1545CT = Device Type = Package type = Forward Current (15A) = Reverse Voltage (45) = Configuration = SSG = Year = Week = Lot Number MBRB1545CT Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package TO-220AB (Pb-Free) D²PAK (Pb-Free) MBR1545CT MBRB1545CT Shipping 50pcs / tube 800pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward Max. Peak One Cycle Non-Repetitive Surge Current (per leg) Symbol VRWM IF(AV) IFSM Condition 50% duty cycle @TC = 125°C, rectangular wave form 8.3 ms, half Sine pulse Max. 45 7.5(per leg) 15(per device) Units V A 180 A • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • MBR1545CT MBRB1545CT MBR1545CT-1 SANGDEST MICROELECTRONICS Technical Data Data Sheet N0736, Rev. - Green Products Electrical Characteristics: Characteristics Max. Forward Voltage Drop* Max. Reverse Current (per leg) * Symbol VF1 VF2 IR1 IR2 Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change * CT LS dv/dt Condition @ 15A, Pulse, TJ = 25 °C @ 15A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125°C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Max. 0.84 0.72 1.0 Units V V mA 15 mA 400 pF 8.0 nH 10,000 V/μs Specification -55 to +150 -55 to +150 3.0 Units °C °C 0.50 °C/W 60 °C/W 2 g Pulse Width < 300µs, Duty Cycle
MBR1545CT 价格&库存
很抱歉,暂时无法提供与“MBR1545CT”相匹配的价格&库存,您可以联系我们找货
MBR1545CT
  • 1+17.817201+2.30256
  • 50+8.5569550+1.10584
  • 100+7.64956100+0.98857
  • 500+6.05760500+0.78284
  • 1000+5.545541000+0.71666
  • 2000+5.114822000+0.66100
  • 5000+4.648915000+0.60079
  • 10000+4.3611010000+0.56360
库存:7124
