MBRF1560CT
MBRF1560CT
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
MBRF1560CT 数据手册
SANGDEST MICROELECTRONICS MBRF1560CT Technical Data Data Sheet N0826, Rev. - Green Products MBRF1560CT SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150°C TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request OUTLINE DRAWING Mechanical Dimensions (In mm): SYMBOL A A1 A2 A3 b b1 b2 b3 b4 c D E e e1 H1 L L1 L2 L3 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Θ5 MIN. 4.30 1.10 2.80 2.50 0.50 1.10 1.50 1.20 1.60 0.55 14.80 9.96 6.50 12.70 1.60 0.80 0.60 3.30 2.99 2.50 TYP. 4.50 1.30 3.00 2.70 0.60 1.20 1.60 1.30 1.70 0.60 15.00 10.16 2.55 5.10 6.70 13.20 1.80 1.00 0.80 3.50 3.19 2.70 5° 4° 10° 5° 5° MAX. 4.70 1.50 3.20 2.90 0.75 1.35 1.75 1.45 1.85 0.75 15.20 10.36 6.90 13.70 2.00 1.20 1.00 3.70 3.39 2.90 ITO-220AB • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRF1560CT Technical Data Data Sheet N0826, Rev. - Green Products Marking Diagram: Where XXXXX is YYWWL MBR F 15 60 CT SSG YY WW L = Device Type = Package type = Forward Current (15A) = Reverse Voltage (60V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AB (Pb-Free) MBRF1560CT Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward Max. Peak One Cycle NonRepetitive Surge Current (per leg) Symbol VRWM IF(AV) IFSM Condition 50% duty cycle @TC =125°C, rectangular wave form 8.3 ms, half Sine pulse Max. 60 7.5(Per leg) 15(Per device) 150 Units V A A • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRF1560CT Technical Data Data Sheet N0826, Rev. - Green Products Electrical Characteristics: Characteristics Max. Forward Voltage Drop* Max. Reverse Current at DC condition (per leg) Max. Reverse Current (per leg)* Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change RSM Isolation Voltage (t = 1.0 second, R. H. < =30%, TA = 25 °C) * Symbol VF1 VF2 IR1 IR2 CT LS dv/dt VISO Condition @ 15A, Pulse, TJ = 25 °C @ 15A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body Clip mounting, the epoxy body away from the heatsink edge by more than 0.110" along the lead direction. Clip mounting, the epoxy body is inside the heatsink. Screw mounting, the epoxy body is inside the heatsink. Max. 0.90 0.80 1.0 Units V V mA 50 mA 300 pF 8.0 nH 10,000 4500 V/μs V 3500 1500 Pulse Width < 300µs, Duty Cycle
MBRF1560CT 价格&库存
很抱歉,暂时无法提供与“MBRF1560CT”相匹配的价格&库存,您可以联系我们找货
