MBRF2045CTP
MBRF2045CTP
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
MBRF2045CTP 数据手册
MBRF2045CTP Technical Data Data Sheet N0074, Rev. A Green Products MBRF2045CTP SCHOTTKY RECTIFIER Applications: • • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Center tap configuration Features: • • • • • • • • • • 150 ℃ TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Terminals: pure tin plated, solderable per MIL-STD-750, Method 2026 This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request OUTLINE DRAWING Mechanical Dimensions: In mm OPTION 1(CJ) OPTION 2(HD) Dim Min Max Min A 4.4 4.6 Max 4.30 4.70 b 0.6TYP 0.50 0.75 b1 1.3TYP 1.30 1.40 b2 1.7TYP 1.70 1.80 b3 1.6TYP 1.50 1.75 b4 1.2TYP 1.10 1.35 0.50 0.75 D C 14.8 15.1 14.80 15.20 E 10.06 10.26 9.96 10.36 e F 0.60TYP 2.55TYP 2.9 2.54TYP 3.1 2.80 3.20 G 6.5 6.9 6.50 6.90 L 12.7 13.7 13.2 12.8 L1 3.4 3.8 3.60 4.00 L2 2.6 3.0 - - 2.50 Q 2.5 2.9 Q1 2.5 2.9 ØR 3.5REF • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 2.90 2.70REF 3.50REF MBRF2045CTP Technical Data Data Sheet N0074, Rev. A Green Products OPTION 3 OPTION 4 Dim Min Max Min Max A 4.53 4.93 4.50 4.90 b 0.71 0.91 0.70 0.90 b1 1.15 1.39 1.33 1.47 C 0.36 0.53 0.45 0.60 D 15.67 16.07 15.67 16.07 E 9.96 10.36 9.96 10.36 e 2.54TYP 2.54 BSC F 2.34 2.76 2.34 2.74 G 6.50 6.90 6.48 6.88 L 12.37 12.77 12.78 13.18 L1 2.23 2.63 3.03 3.43 Q 2.56 2.96 2.56 2.96 Q1 3.10 3.50 3.10 3.50 ØR 2.98 3.38 3.08 3.28 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRF2045CTP Technical Data Data Sheet N0074, Rev. A Green Products OPTION 5 (SR) ITO-220AB • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRF2045CTP Technical Data Data Sheet N0074, Rev. A Green Products Marking Diagram: Where XXXXX is YYWWL MBR F 20 45 CTP SSG YY WW L = Device Type = Package type = Forward Current (20A) = Reverse Voltage (45V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AB (Pb-Free) MBRF2045CTP Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current (per device) Peak One Cycle Non-Repetitive Surge Current (per leg) Symbol VRRM VRWM VR Condition Max. Units - 45 V 20 A 150 A IF (AV) 50% duty cycle @TC =116°C, rectangular wave form IFSM 8.3 ms, half Sine pulse • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRF2045CTP Technical Data Data Sheet N0074, Rev. A Green Products Electrical Characteristics: Characteristics Forward Voltage Drop(per leg) * Reverse Current (per leg) * Reverse Current (per leg) * Junction Capacitance (per leg) Voltage Rate of Change * Symbol VF1 VF2 IR1 IR2 CT dv/dt Condition @ 20A, Pulse, TJ = 25 °C @ 20A, Pulse, TJ = 125 °C @VR = rated VR TC = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz - Typ. 0.74 0.70 Max. 0.84 0.72 Units V V 0.025 1.0 mA 9 15.0 mA 250 400 pF - 10,000 V/μs Pulse Width < 300µs, Duty Cycle
MBRF2045CTP 价格&库存
很抱歉,暂时无法提供与“MBRF2045CTP”相匹配的价格&库存,您可以联系我们找货
