MBRF2060CTL
MBRF2060CTL
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    特性:125℃ Tj 工作。 中心抽头配置。 低正向压降。 高纯度、高温环氧树脂封装,增强机械强度和防潮性。 高频操作。 保护环,增强耐用性和长期可靠性。应用:开关电源。 转换器
MBRF2060CTL 数据手册
MBRF2060CTL Technical Data Data Sheet N0149, Rev. B Green Products MBRF2060CTL SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • • 125 ℃ TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Terminals: pure tin plated, solderable per MIL-STD-750, Method 2026 This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request OUTLINE DRAWING Mechanical Dimensions: In mm OPTION 1(CJ) OPTION 2(HD) Dim Min Max Min Max A 4.4 4.6 4.30 4.70 b 0.6TYP 0.50 0.75 b1 1.3TYP 1.30 1.40 b2 1.7TYP 1.70 1.80 b3 1.6TYP 1.50 1.75 b4 1.2TYP 1.10 1.35 C 0.60TYP 0.50 0.75 D 14.8 15.1 14.80 15.20 E 10.06 10.26 9.96 10.36 e 2.55TYP 2.54TYP F 2.9 3.1 2.80 3.20 G 6.5 6.9 6.50 6.90 L 12.7 13.7 12.8 13.2 L1 3.4 3.8 3.60 4.00 L2 2.6 3.0 - - Q 2.5 2.9 2.50 2.90 Q1 2.5 2.9 ØR 3.5REF ITO-220AB • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 2.70REF 3.50REF MBRF2060CTL Technical Data Data Sheet N0149, Rev. B Green Products Marking Diagram: Where XXXXX is YYWWL MBR F 20 60 CTL SSG YY WW L = Device Type = Package Type = Forward Current (20A) = Reverse Voltage (60V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AB (Pb-Free) MBRF2060CTL Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Output Current(per device) Peak One Cycle Non-Repetitive Surge Current (per leg) Symbol VRRM VRWM VR Io IFSM Condition - Max. 60 Units V 50% duty cycle @TC =80°C, rectangular wave form 20 A 8.3 ms, half Sine pulse 150 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRF2060CTL Technical Data Data Sheet N0149, Rev. B Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Reverse Current (per leg) * Junction Capacitance (per leg) Voltage Rate of Change * Symbol VF1 IR1 CT dv/dt Condition @ 10A, Pulse, TJ = 25 °C Typ. 0.62 Max. 0.69 Units V @VR = rated VR Pulse TJ = 25 °C @VR = 5V, TC = 25 °C fSIG = 1MHz - 0.15 1.0 mA 250 400 pF - 10,000 V/μs Specification -55 to +125 -55 to +150 2.3 Units °C °C 0.50 °C/W 2 g Pulse Width < 300µs, Duty Cycle
MBRF2060CTL 价格&库存
很抱歉,暂时无法提供与“MBRF2060CTL”相匹配的价格&库存,您可以联系我们找货
