MBRF3045CT
MBRF3045CT
    SMCDIODESOLUTIONS(桑德斯)
    ITO-220AB
MBRF3045CT 数据手册
MBRF3035CT MBRF3040CT MBRF3045CT Technical Data Data Sheet N0831 Rev. A Green Products MBRF3035CT /MBRF3040CT /MBRF3045CT SCHOTTKY RECTIFIER Applications: • • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Center tap configuration Features: • • • • • • • • • • 150 ℃ TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Terminals: pure tin plated, solderable per MIL-STD-750, Method 2026 This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request OUTLINE DRAWING Mechanical Dimensions: In mm OPTION 1(CJ) OPTION 2(HD) Dim Min Max Min Max A 4.4 4.6 4.30 4.70 b 0.6TYP 0.50 0.75 b1 1.3TYP 1.30 1.40 b2 1.7TYP 1.70 1.80 b3 1.6TYP 1.50 1.75 b4 1.2TYP 1.10 1.35 C 0.60TYP 0.50 0.75 D 14.8 15.1 14.80 15.20 E 10.06 10.26 9.96 10.36 e F 2.55TYP 2.9 3.1 2.54TYP 2.80 3.20 G 6.5 6.9 6.50 6.90 L 12.7 13.7 12.8 13.2 L1 3.4 3.8 3.60 4.00 L2 2.6 3.0 - - 2.50 Q 2.5 2.9 Q1 2.5 2.9 ØR 3.5REF • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 2.90 2.70REF 3.50REF MBRF3035CT MBRF3040CT MBRF3045CT Technical Data Data Sheet N0831 Rev. A Green Products OPTION 3 OPTION 4 Dim Min Max Min Max A 4.53 4.93 4.50 4.90 b 0.71 0.91 0.70 0.90 b1 1.15 1.39 1.33 1.47 C 0.36 0.53 0.45 0.60 D 15.67 16.07 15.67 16.07 E 9.96 10.36 9.96 10.36 e 2.54TYP 2.54 BSC F 2.34 2.76 2.34 2.74 G 6.50 6.90 6.48 6.88 L 12.37 12.77 12.78 13.18 L1 2.23 2.63 3.03 3.43 2.56 2.96 2.56 2.96 Q1 3.10 3.50 3.10 3.50 ØR 2.98 3.38 3.08 3.28 Q • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRF3035CT MBRF3040CT MBRF3045CT Technical Data Data Sheet N0831 Rev. A Green Products OPTION 5 (SR) ITO-220AB • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRF3035CT MBRF3040CT MBRF3045CT Technical Data Data Sheet N0831 Rev. A Green Products Marking Diagram: Where XXXXX is YYWWL MBR F 30 35 CT SSG YY WW L = Device Type = Package type = Forward Current (30A) = Reverse Voltage (35V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AB (Pb-Free) MBRF3035CT Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current (per device) Peak One Cycle Non-Repetitive Surge Current (per leg) Symbol VRRM VRWM VR IF (AV) IFSM Condition - 50% duty cycle @TC =123 °C, rectangular wave form 8.3 ms, half Sine pulse Max. MBRF3035CT MBRF3040CT MBRF3045CT 15(per leg) 30(per device) 240 35 40 45 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • Units V A A MBRF3035CT MBRF3040CT MBRF3045CT Technical Data Data Sheet N0831 Rev. A Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg)* Symbol VF1 VF2 Reverse Current (per leg) * IR1 IR2 Junction Capacitance (per leg) Series Inductance (per leg) Voltage Rate of Change CT LS dv/dt Condition @ 15 A, Pulse, TJ = 25 °C @ 30 A, Pulse, TJ = 25 °C @ 15 A, Pulse, TJ = 125 °C @ 30 A, Pulse, TJ = 125 °C @VR = rated VR TC = 25 °C @VR = rated VR TC = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Typ. 0.60 0.8 0.55 0.73 0.03 Max. 0.70 0.84 0.57 0.75 1.0 Units V 15 100 mA 300 800 pF 7.5 - nH - 10,000 V/μs Specification -55 to +150 -55 to +150 2.4 Units °C °C °C/W 2 g V mA *Pulse Width < 300µs, Duty Cycle
MBRF3045CT 价格&库存
很抱歉,暂时无法提供与“MBRF3045CT”相匹配的价格&库存,您可以联系我们找货
