MBRF3030CT
MBRF3030CT
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
MBRF3030CT 数据手册
SANGDEST MICROELECTRONICS MBRF3030CT Technical Data Data Sheet N0830, Rev. - Green Products MBRF3030CT SCHOTTKY RECTIFIER Applications: • • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Center tap configuration Features: • • • • • • • • • 150 ℃ TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request OUTLINE DRAWING Mechanical Dimensions: In Inches / mm OPTION 1 OPTION 2 Dim Min Max Min Max A 4.4 4.6 4.30 4.70 b 0.6TYP 0.50 0.75 b1 1.3TYP 1.30 1.40 b2 1.7TYP 1.70 1.80 b3 1.6TYP 1.50 1.75 b4 1.2TYP 1.10 1.35 0.50 0.75 D C 14.8 15.1 14.80 15.20 E 10.06 10.26 9.96 10.36 e 0.60TYP 2.55TYP 2.54TYP F 2.9 3.1 2.80 3.20 G 6.5 6.9 6.50 6.90 L 12.7 13.7 12.8 13.2 L1 3.4 3.8 3.60 4.00 L2 2.6 3.0 - - Q 2.5 2.9 2.50 2.90 Q1 2.5 2.9 ØR 3.5REF 2.70REF 3.50REF • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRF3030CT Technical Data Data Sheet N0830, Rev. - Green Products OPTION 3 OPTION 4 Dim Min Max Min Max A 4.53 4.93 4.50 4.90 b 0.71 0.91 0.70 0.90 b1 1.15 1.39 1.33 1.47 C 0.36 0.53 0.45 0.60 D 15.67 16.07 15.67 16.07 E 9.96 10.36 9.96 10.36 e 2.54TYP 2.54 BSC F 2.34 2.76 2.34 2.74 G 6.50 6.90 6.48 6.88 L 12.37 12.77 12.78 13.18 L1 2.23 2.63 3.03 3.43 Q 2.56 2.96 2.56 2.96 Q1 3.10 3.50 3.10 3.50 ØR 2.98 3.38 3.08 3.28 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRF3030CT Technical Data Data Sheet N0830, Rev. - Green Products OPTION 5 (SR) ITO-220AB • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRF3030CT Technical Data Data Sheet N0830, Rev. - Green Products Marking Diagram: Where XXXXX is YYWWL MBR F 30 30 CT SSG YY WW L = Device Type = Package type = Forward Current (30A) = Reverse Voltage (30V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AB (Pb-Free) MBRF3030CT Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward Current Max. Peak One Cycle NonRepetitive Surge Current Symbol VRWM IF(AV) IFSM Condition 50% duty cycle @TC =123 °C, rectangular wave form 8.3 ms, half Sine pulse Max. 30 Units V 15(per leg) 30(per device) 240 A A • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRF3030CT Technical Data Data Sheet N0830, Rev. - Green Products Electrical Characteristics: Characteristics Max. Forward Voltage Drop* Max. Reverse Current (per leg) * Symbol VF1 VF2 IR1 IR2 Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change CT LS dv/dt Condition @ 30 A, Pulse, TJ = 25 °C @ 30 A, Pulse, TJ = 125 °C @VR = rated VR TC = 25 °C @VR = rated VR TC = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Max. 0.84 0.72 1.0 Units V V mA 40 mA 500 pF 8.0 nH 10,000 V/μs Specification -55 to +150 -55 to +150 2.4 Units °C °C °C/W 2.0 g Pulse Width < 300µs, Duty Cycle
MBRF3030CT
1. 物料型号: - 型号:MBRF3030CT - 封装:ITO-220AB (Pb-Free)
2. 器件简介: - MBRF3030CT是一款肖特基整流器,应用于开关电源、转换器、自由轮流通二极管和反向电池保护等场合。
3. 引脚分配: - 该器件具有中心抽头配置,用于增强机械强度和防潮性能。
4. 参数特性: - 最大反向峰值电压(VRWM):30V - 最大平均正向电流(IF(AV)):15A(每腿,50%占空比,Tc=123°C时) - 最大正向电流(IFSM):240A(8.3ms,半正弦脉冲) - 最大正向电压降(VF):0.84V(30A,脉冲,T=25°C时)
5. 功能详解: - 150℃ TJ操作 - 低正向电压降 - 高纯度、耐高温环氧封装 - 高频操作 - 保护环增强了鲁棒性和长期可靠性 - 无铅设备 - 所有SMC零件都可以追溯到晶圆批次
6. 应用信息: - 开关电源、转换器、自由轮流通二极管、反向电池保护、中心抽头配置。
7. 封装信息: - 机械尺寸以英寸/毫米为单位,具体尺寸参数已在PDF文件中列出。 - 封装风格:ITO-220AB - 每管装50片
MBRF3030CT 价格&库存
很抱歉,暂时无法提供与“MBRF3030CT”相匹配的价格&库存,您可以联系我们找货
