MBR2050CT
MBR2050CT
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    特性:150℃ Tj 操作。 中心抽头配置。 低正向压降。 高纯度、高温环氧树脂封装,增强机械强度和防潮性。 高频操作。 保护环,增强耐用性和长期可靠性。应用:开关电源。 转换器
MBR2050CT 数据手册
MBR2050/2060CT MBRB2050CT MBR2050/2060CT-1 Technical Data Data Sheet N0034, Rev. B Green Products MBR2050/2060CT MBRB2050CT MBR2050/2060CT-1 SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150 ℃ TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request MBR2050CT MBR2060CT TO-220AB Case styles MBRB2050CT D2PAK MBR2050CT-1 MBR2060CT-1 TO-262 Mechanical Dimensions: In Inches / mm TO-220AB(HD) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR2050/2060CT MBRB2050CT MBR2050/2060CT-1 Technical Data Data Sheet N0034, Rev. B Green Products Symbol A A1 A2 b b1 c c1 D D1 E E1 E2 e H L L1 L2 L3 e e1 e2 e3 Dimensions in millimeters Min. Typical Max. 4.55 0 2.59 0.71 0.36 1.17 8.55 6.40 10.01 7.6 9.98 14.6 2.00 1.17 0 4.70 0.10 2.69 0.81 1.27 0.38 1.27 8.70 0.61 1.37 8.85 10.16 10.31 10.08 2.54 15.1 2.30 1.27 10.18 0.25BSC 5° 4° 4° D2PAK(HD) TO-262 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 4.85 0.25 2.89 0.96 15.6 2.70 1.40 2.20 8° MBR2050/2060CT MBRB2050CT MBR2050/2060CT-1 Technical Data Data Sheet N0034, Rev. B Green Products Marking Diagram: Where XX is Reverse Voltage Where XXXXX is YYWWL MBR B 20 XX CT/CT-1 SSG YY WW L MBR20XXCT = Device Type = Package type = Forward Current (20A) = Reverse Voltage (50/60V) = Configuration = SSG = Year = Week = Lot Number MBRB2050CT Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device MBR20XXCT MBR20XXCT-1 Package TO-220AB (Pb-Free) D²PAK (Pb-Free) MBRB2050CT Shipping 50pcs / tube 800pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Output Current(Per device) Peak One Cycle Non-Repetitive Surge Current(per leg) Symbol VRRM VRWM VR Condition - 50 60 Max. MBR2050CT MBR2060CT Units V Io 50% duty cycle @TC =80°C, rectangular wave form 20 A IFSM 8.3 ms, half Sine pulse 150 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR2050/2060CT MBRB2050CT MBR2050/2060CT-1 Technical Data Data Sheet N0034, Rev. B Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg)* Symbol VF1 VF2 Reverse Current (per leg)* IR1 IR2 Junction Capacitance (per leg) Series Inductance (per leg) Max. Voltage Rate of Change * CT LS dv/dt Condition @ 10A, Pulse, TJ = 25 ℃ @ 20A, Pulse, TJ = 25 °C @ 10A, Pulse, TJ = 125 ℃ @ 20A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 ℃ @VR = rated VR TJ = 125 ℃ @VR = 5V, TC = 25 ℃ fSIG = 1MHz Measured lead to lead 5 mm from package body - Typ. 0.66 0.85 0.61 0.75 Max. 0.80 0.95 0.70 0.85 Units 0.075 1.0 mA 4 150 mA 260 400 pF 8.0 - nH - 10,000 V/μs V V Pulse Width < 300µs, Duty Cycle
MBR2050CT
物料型号: - MBR2050/2060CT - MBRB2050CT - MBR2050/2060CT-1
器件简介: 这些是肖特基整流器,适用于开关电源、转换器、续流二极管、防反电池保护等应用。
引脚分配: - 02:阳极公共 - 03:阳极节点
参数特性: - 150℃的TJ操作 - 中心抽头配置 - 低正向电压降 - 高纯度、耐高温环氧封装,增强机械强度和防潮性 - 高频操作 - 护圈增强了韧性和长期可靠性 - 无铅设备 - 所有SMC部件都可以追溯到晶片批次 - 可提供额外的测试
功能详解: - 提供了详细的电气特性,包括正向电压降、反向电流、结电容、串联电感和最大电压变化率等。
应用信息: - 适用于需要高效率和高可靠性的场合,如开关电源和电池保护。
封装信息: - 提供了TO-220AB和D2PAK两种封装类型的详细机械尺寸。
免责声明: - 信息、规格和尺寸如有更改,恕不另行通知以改进产品特性。 - 在高可靠性要求的应用中,应使用具有保证安全性的半导体器件或通过用户的故障安全预防措施或其他安排来确保安全。
订购信息: - 提供了TO-220AB和D2PAK封装的订购信息,包括每个包装的数量。
联系方式: - 网站:[http://www.smc-diodes.com](http://www.smc-diodes.com) - 邮箱:sales@smc-diodes.com
MBR2050CT 价格&库存
很抱歉,暂时无法提供与“MBR2050CT”相匹配的价格&库存,您可以联系我们找货
MBR2050CT
  • 1+12.584051+1.62794
