MBR3060CT
MBRB3060CT
MBR3060CT-1
SANGDEST
MICROELECTRONICS
Technical Data
Data Sheet N0738, Rev. -
Green Products
MBR3060CT /MBRB3060CT /MBR3060CT-1
SCHOTTKY RECTIFIER
Applications:
Switching power supply
Converters
Free-Wheeling diodes
Reverse battery protection
Features:
150 °C TJ operation
Center tap configuration
Low forward voltage drop
High purity, high temperature epoxy encapsulation for enhanced mechanical strength and
moisture resistance
High frequency operation
Guard ring for enhanced ruggedness and long term reliability
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
MBR30…CT
TO-220AB
Case styles
MBRB30…CT
D2PAK
Mechanical Dimensions: In Inches / mm
MBR30…CT-1
TO-262
TO-220AB
• Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113 (86) 25-87123907 •
• FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn •
MBR3060CT
MBRB3060CT
MBR3060CT-1
SANGDEST
MICROELECTRONICS
Technical Data
Green Products
Symbol
A
A1
A2
b
b1
c
c1
D
D1
E
E1
E2
e
H
L
L1
L2
L3
e
e1
e2
e3
D2PAK
Dimensions in
millimeters
Min. Typical Max.
4.55
0.71
0.36
1.17
8.55
6.40
10.01
7.6
9.98
14.6
2.00
1.17
0.10
2.69
0.81
1.27
0.38
1.27
8.70
0.61
1.37
8.85
10.16
10.31
10.08
2.54
15.1
2.30
1.27
10.18
0.25BSC
5°
4°
4°
4.85
0.25
2.89
0.96
15.6
2.70
1.40
2.20
8°
TO-262
MBR3060CT
MBRB3060CT
MBR3060CT-1
SANGDEST
MICROELECTRONICS
Technical Data
Green Products
Marking Diagram:
Where XXXXX is YYWWL
MBR
B
30
60
CT/CT-1
SSG
YY
WW
L
MBR3060CT
= Device Type
= Package type
= Forward Current (30A)
= Reverse Voltage (60V)
= Configuration
= SSG
= Year
= Week
= Lot Number
MBRB3060CT
Cautions:Molding resin
Epoxy resin UL:94V-0
Ordering Information:
Device
Package
TO-220AB
(Pb-Free)
D²PAK
(Pb-Free)
MBR3060CT
MBRB3060CT
Shipping
50pcs / tube
800pcs / reel
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
Maximum Ratings:
Characteristics
Peak Inverse Voltage
Max. Average Forward
Max. Peak One Cycle
Non-Repetitive Surge Current
(per leg)
Symbol
VRWM
IF(AV)
Condition
50% duty cycle @TC = 95°C,
rectangular wave form
IFSM
8.3 ms, half Sine pulse
Max.
60
Units
V
30
A
200
A
MBR3060CT
MBRB3060CT
MBR3060CT-1
SANGDEST
MICROELECTRONICS
Technical Data
Green Products
Electrical Characteristics:
Characteristics
Max. Forward Voltage Drop
(per leg)*
Max. Reverse Current (per
leg)*
Symbol
Max.
Units
VF1
@ 15A, Pulse, TJ = 25 °C
0.77
V
VF2
@ 15 A, Pulse, TJ = 125 °C
@VR = rated VR
TJ = 25 °C
@VR = rated VR
TJ = 125 °C
@VR = 5V, TC = 25 °C
fSIG = 1MHz
0.67
V
5.0
mA
IR1
IR2
Max. Junction Capacitance
(per leg)
Max. Voltage Rate of Change
Condition
CT
dv/dt
100
mA
700
pF
10,000
V/μs
Specification
-55 to +150
-55 to +150
Units
°C
°C
Pulse Width < 300µs, Duty Cycle
很抱歉,暂时无法提供与“MBR3060CT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+14.382491+1.85538
- 50+6.7710850+0.87349
- 100+6.02987100+0.77787
- 500+4.72900500+0.61006
- 1000+4.310241000+0.55604
- 2000+3.957922000+0.51059
- 5000+3.576785000+0.46142
- 10000+3.3413210000+0.43104
