MBRF15200CT
MBRF15200CT
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
MBRF15200CT 数据手册
MBRF15200CT Technical Data Data Sheet N1825, Rev. - Green Products MBRF15200CT SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150℃ TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request OUTLINE DRAWING Mechanical Dimensions: In mm SYMBOL A A1 A2 A3 b b1 b2 b3 b4 c D E e e1 H1 L L1 L2 L3 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Θ5 MIN. 4.30 1.10 2.80 2.50 0.50 1.10 1.50 1.20 1.60 0.55 14.80 9.96 6.50 12.70 1.60 0.80 0.60 3.30 2.99 2.50 TYP. 4.50 1.30 3.00 2.70 0.60 1.20 1.60 1.30 1.70 0.60 15.00 10.16 2.55 5.10 6.70 13.20 1.80 1.00 0.80 3.50 3.19 2.70 5° 4° 10° 5° 5° ITO-220AB (HD) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MAX. 4.70 1.50 3.20 2.90 0.75 1.35 1.75 1.45 1.85 0.75 15.20 10.36 6.90 13.70 2.00 1.20 1.00 3.70 3.39 2.90 MBRF15200CT Technical Data Data Sheet N1825, Rev. - Green Products Marking Diagram: Where XXXXX is YYWWL MBR F 15 200 CT SSG YY WW L = Device Type = Package type = Forward Current (15A) = Reverse Voltage (200V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AB (Pb-Free) MBRF15200CT Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Forward Current (per device) Peak One Cycle Non-Repetitive Surge Current(per leg) Symbol VRRM VRWM VR Condition - Max. Units 200 V IF(AV) 50% duty cycle @TC = 105°C, rectangular wave form 15 A IFSM 8.3 ms, half Sine pulse 130 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRF15200CT Technical Data Data Sheet N1825, Rev. - Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Reverse Current (per leg) * Symbol VF1 VF2 IR1 IR2 Junction Capacitance (per leg) * CT Condition @ 7.5 A, Pulse, TJ = 25 °C @ 7.5 A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Max. 0.98 0.88 Units V V 1.00 mA 15.0 mA 150 pF Specification -55 to +150 -55 to +150 Units °C °C 3.5 °C/W 2 g Pulse Width < 300µs, Duty Cycle
MBRF15200CT
物料型号: - 型号:MBRF15200CT - 封装类型:ITO-220AB(无铅)
器件简介: MBRF15200CT是一款肖特基整流器,适用于开关电源、转换器、飞轮二极管和防反接保护等应用。具有150℃的工作结温,中心抽头配置,低正向电压降,高纯度、耐高温环氧树脂封装,增强了机械强度和防潮性能,适用于高频操作,带有增强环以提高坚固性和长期可靠性。
引脚分配: - 中心抽头(Center Tap)
参数特性: - 重复峰值反向电压:200V - 工作峰值反向电压:200V - DC阻断电压:200V - 平均正向电流(每个器件):15A(50%占空比,Tc=105°C,矩形波形) - 单腿的峰值非重复浪涌电流:130A(8.3ms,半正弦脉冲) - 正向电压降(每腿):25°C时7.5A脉冲下0.98V,125°C时7.5A脉冲下0.88V - 反向电流(每腿):25°C下1.00mA,125°C下15.0mA - 每个腿的结电容:25°C下5V时150pF(1MHz)
功能详解: MBRF15200CT具有低正向电压降,适用于高频开关电源应用,中心抽头设计使其适用于需要中心抽头整流器的场合。此外,该器件还具有较高的反向电压和正向电流承受能力,适用于较高电压和电流的应用场合。
应用信息: 适用于开关电源、转换器、飞轮二极管和防反接保护等应用。
封装信息: - 封装类型:ITO-220AB(无铅) - 包装:每管50个
MBRF15200CT 价格&库存
很抱歉,暂时无法提供与“MBRF15200CT”相匹配的价格&库存,您可以联系我们找货
