MBRF3060CT
MBRF3060CT
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    一对共阴极
MBRF3060CT 数据手册
MBRF3060CT Technical Data Data Sheet N0177, Rev. B Green Products MBRF3060CT SCHOTTKY RECTIFIER Applications: • • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Center tap configuration Features: • • • • • • • • • • 175 °C TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Terminals: pure tin plated, solderable per MIL-STD-750, Method 2026 This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request OUTLINE DRAWING Mechanical Dimensions: In mm OPTION 1(CJ) OPTION 2(HD) Dim Min Max Min A 4.4 4.6 Max 4.30 4.70 b 0.6TYP 0.50 0.75 b1 1.3TYP 1.30 1.40 b2 1.7TYP 1.70 1.80 b3 1.6TYP 1.50 1.75 b4 1.2TYP 1.10 1.35 C 0.60TYP 0.50 0.75 D 14.8 15.1 14.80 15.20 E 10.06 10.26 9.96 10.36 e 2.55TYP 2.54TYP F 2.9 3.1 2.80 3.20 G 6.5 6.9 6.50 6.90 L 12.7 13.7 12.8 13.2 L1 3.4 3.8 3.60 4.00 L2 2.6 3.0 - - Q 2.5 2.9 2.50 2.90 Q1 2.5 2.9 ØR 3.5REF 2.70REF 3.50REF • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRF3060CT Technical Data Data Sheet N0177, Rev. B Green Products OPTION 3 (SR) ITO-220AB • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRF3060CT Technical Data Data Sheet N0177, Rev. B Green Products Marking Diagram: Where XXXXX is YYWWL MBR F 30 60 CT SSG YY WW L = Device Type = Package type = Forward Current (30A) = Reverse Voltage (60V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AB (Pb-Free) MBRF3060CT Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current (per device) Peak One Cycle Non-Repetitive Surge Current (per leg) Symbol VRRM VRWM VR Condition - IF (AV) 50% duty cycle @TC = 95°C, rectangular wave form IFSM 8.3 ms, half Sine pulse Max. Units 60 V 30 A 200 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRF3060CT Technical Data Data Sheet N0177, Rev. B Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg)* Reverse Current (per leg)* Symbol VF1 VF2 IR1 IR2 Junction Capacitance (per leg) Series Inductance (per leg) Voltage Rate of Change RSM Isolation Voltage (t = 1.0 second, R. H. < =30%, TA = 25 °C) * CT LS dv/dt VISO Condition @ 15A, Pulse, TJ = 25 °C @ 15A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body Clip mounting, the epoxy body away from the heatsink edge by more than 0.110" along the lead direction. Clip mounting, the epoxy body is inside the heatsink. Screw mounting, the epoxy body is inside the heatsink. Typ. 0.69 0.66 Max. 0.70 0.67 Units V V 0.015 1.0 mA 0.9 100 mA 300 700 pF 8.0 - nH - 10,000 V/μs - 4500 - 3500 - 1500 V Pulse Width < 300µs, Duty Cycle
MBRF3060CT
物料型号:MBRF3060CT
器件简介:MBRF3060CT是一款肖特基整流器,常用于开关电源、转换器、自由轮二极管、反向电池保护和中心抽头配置。
引脚分配:文档提供了两种选项(CJ和HD)的机械尺寸图,但没有直接提供具体的引脚分配图。
参数特性: - 工作温度范围:-55°C 至 +175°C - 直流阻断电压:60V - 平均整流正向电流:在95°C和50%占空比条件下为30A - 正向电压降:在15A和25°C下为0.69V,125°C下为0.66V - 反向电流:在额定反向电压和25°C下为0.015mA,125°C下为100mA - 结电容:在5V反向电压和25°C下,信号频率为1MHz时为300至700pF - 串联电感:从封装体到引脚5mm处测量为8.0nH - 电压变化率:10,000V/μs - 隔离电压:根据安装方式不同,值在3500V至4500V之间
功能详解:该器件具有低正向电压降、高频率操作能力、增强的机械强度和防潮性,以及高纯度、高温环氧封装。
应用信息:适用于需要高效率和高可靠性的电源转换场合。
封装信息:提供ITO-220AB封装选项,是无铅(Pb-Free)产品。
订购信息:MBRF3060CT ITO-220AB封装,每管50个。
免责声明:信息包括规格和尺寸可能会在不通知的情况下更改,以改进产品特性。在极端高可靠性要求的应用中,应使用具有保证安全的半导体器件或通过用户的故障安全预防措施或其他安排来确保安全。
MBRF3060CT 价格&库存
很抱歉,暂时无法提供与“MBRF3060CT”相匹配的价格&库存,您可以联系我们找货
