MBRF2080CTL
MBRF2080CTL
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    特性:150℃ Tj 工作。 中心抽头配置。 低正向压降。 高纯度、高温环氧树脂封装,增强机械强度和防潮性。 高频工作。 保护环,增强耐用性和长期可靠性。应用:开关电源。 转换器
MBRF2080CTL 数据手册
MBRF2080CTL Technical Data Data Sheet N0632, Rev. B Green Products MBRF2080CTL SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • • 150 ℃ TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Terminals: pure tin plated, solderable per MIL-STD-750, Method 2026 This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request OUTLINE DRAWING Mechanical Dimensions: In mm SYMBOL A A1 A2 A3 b b1 b2 b3 b4 c D E e e1 H1 L L1 L2 L3 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Θ5 MIN. 4.30 1.10 2.80 2.50 0.50 1.10 1.50 1.20 1.60 0.55 14.80 9.96 6.50 12.70 1.60 0.80 0.60 3.30 2.99 2.50 TYP. 4.50 1.30 3.00 2.70 0.60 1.20 1.60 1.30 1.70 0.60 15.00 10.16 2.55 5.10 6.70 13.20 1.80 1.00 0.80 3.50 3.19 2.70 5° 4° 10° 5° 5° ITO-220AB (HD) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MAX. 4.70 1.50 3.20 2.90 0.75 1.35 1.75 1.45 1.85 0.75 15.20 10.36 6.90 13.70 2.00 1.20 1.00 3.70 3.39 2.90 MBRF2080CTL Technical Data Data Sheet N0632, Rev. B Green Products Marking Diagram: Where XXXXX is YYWWL MBR F 20 80 CTL SSG YY WW L = Device Type = Package Type = Forward Current (20A) = Reverse Voltage (80V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AB (Pb-Free) MBRF2080CTL Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current (per device) Peak One Cycle Non-Repetitive Surge Current (per leg) Symbol VRRM VRWM VR Condition Max. Units - 80 V IF (AV) 50% duty cycle @TC =100°C, rectangular wave form 20 A IFSM 8.3 ms, half Sine pulse 150 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRF2080CTL Technical Data Data Sheet N0632, Rev. B Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Reverse Current (per leg) * Symbol VF1 IR1 IR2 Junction Capacitance (per leg) * CT Condition @ 10 A, Pulse, TJ = 25 °C @VR = rated VR TC = 25 °C @VR = rated VR TC = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Typ. Max. Units 0.68 0.75 V 0.05 1.0 mA 28 50 mA 180 500 pF Pulse Width < 300µs, Duty Cycle
MBRF2080CTL 价格&库存
很抱歉,暂时无法提供与“MBRF2080CTL”相匹配的价格&库存,您可以联系我们找货
