MBRF3060CTP
MBRF3060CTP
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
MBRF3060CTP 数据手册
MBRF3060CTP Technical Data Data Sheet N0125, Rev. A Green Products MBRF3060CTP SCHOTTKY RECTIFIER Applications: • Switching power supply • Converters • Free-Wheeling diodes • Reverse battery protection Features: • • • • • • • • • • 150 °C TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Terminals: pure tin plated, solderable per MIL-STD-750, Method 2026 This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request OUTLINE DRAWING Mechanical Dimensions: In mm OPTION 1(CJ) OPTION 2(HD) Dim Min Max Min A 4.4 4.6 4.30 Max 4.70 b 0.6TYP 0.50 0.75 b1 1.3TYP 1.30 1.40 b2 1.7TYP 1.70 1.80 b3 1.6TYP 1.50 1.75 b4 1.2TYP 1.10 1.35 C 0.60TYP 0.50 0.75 D 14.8 15.1 14.80 15.20 E 10.06 10.26 9.96 10.36 e F 2.55TYP 2.9 3.1 2.54TYP 2.80 3.20 G 6.5 6.9 6.50 6.90 L 12.7 13.7 12.8 13.2 L1 3.4 3.8 3.60 4.00 L2 2.6 3.0 - - Q 2.5 2.9 2.50 2.90 Q1 2.5 2.9 ØR 3.5REF • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 2.70REF 3.50REF MBRF3060CTP Technical Data Data Sheet N0125, Rev. A Green Products OPTION 3 OPTION 4 Dim Min Max Min Max A 4.53 4.93 4.50 4.90 b 0.71 0.91 0.70 0.90 b1 1.15 1.39 1.33 1.47 C 0.36 0.53 0.45 0.60 D 15.67 16.07 15.67 16.07 E 9.96 10.36 9.96 10.36 e 2.54TYP 2.54 BSC F 2.34 2.76 2.34 2.74 G 6.50 6.90 6.48 6.88 L 12.37 12.77 12.78 13.18 L1 2.23 2.63 3.03 3.43 Q 2.56 2.96 2.56 2.96 Q1 3.10 3.50 3.10 3.50 ØR 2.98 3.38 3.08 3.28 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRF3060CTP Technical Data Data Sheet N0125, Rev. A Green Products OPTION 5 (SR) ITO-220AB • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRF3060CTP Technical Data Data Sheet N0125, Rev. A Green Products Marking Diagram: Where XXXXX is YYWWL MBR F 30 60 CTP SSG YY WW L = Device Type = Package type = Forward Current (30A) = Reverse Voltage (60V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AB (Pb-Free) MBRF3060CTP Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current (per device) Peak One Cycle Non-Repetitive Surge Current (per leg) Symbol VRRM VRWM VR Condition - IF (AV) 50% duty cycle @TC = 95°C, rectangular wave form IFSM 8.3 ms, half Sine pulse Max. Units 60 V 30 A 200 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRF3060CTP Technical Data Data Sheet N0125, Rev. A Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg)* Reverse Current (per leg)* Symbol VF1 VF2 IR1 IR2 Junction Capacitance (per leg) Voltage Rate of Change RSM Isolation Voltage (t = 1.0 second, R. H. < =30%, TA = 25 °C) * CT dv/dt VISO Condition @ 15A, Pulse, TJ = 25 °C @ 15A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Clip mounting, the epoxy body away from the heatsink edge by more than 0.110" along the lead direction. Clip mounting, the epoxy body is inside the heatsink. Screw mounting, the epoxy body is inside the heatsink. Typ. 0.68 0.66 Max. 0.77 0.67 Units V V 0.01 1.0 mA 0.9 100 mA 300 700 pF - 10,000 V/μs - 4500 - 3500 - 1500 V Pulse Width < 300µs, Duty Cycle
MBRF3060CTP
物料型号:MBRF3060CTP 器件简介:肖特基整流器,适用于开关电源、转换器、自由轮二极管、反向电池保护。
引脚分配:中心抽头配置,纯锡镀层,符合MIL-STD-750方法2026的可焊性。
参数特性:最高工作结温150°C,低正向电压降,高纯度、耐高温环氧树脂封装,高频率操作,保护环提高耐用性和长期可靠性。
功能详解:提供高效的整流功能,低正向压降和低反向电流,适用于高频应用。
应用信息:适用于开关电源、转换器、自由轮二极管、反向电池保护。
封装信息:ITO-220AB封装,无铅,50pcs/管装运。
以上信息摘自SMC的PDF文档,提供了MBRF3060CTP肖特基整流器的详细技术数据。
MBRF3060CTP 价格&库存
很抱歉,暂时无法提供与“MBRF3060CTP”相匹配的价格&库存,您可以联系我们找货
