MBRF2045CT
MBRF2045CT
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    一对共阴极
MBRF2045CT 数据手册
MBRF2045CT Technical Data Data Sheet N0828, Rev. A Green Products MBRF2045CT SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • • 150°C TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Terminals: pure tin plated, solderable per MIL-STD-750, Method 2026 This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request OUTLINE DRAWING Mechanical Dimensions (In mm): SYMBOL A A1 A2 A3 b b1 b2 b3 b4 c D E e e1 H1 L L1 L2 L3 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Θ5 MIN. 4.30 1.10 2.80 2.50 0.50 1.10 1.50 1.20 1.60 0.55 14.80 9.96 6.50 12.70 1.60 0.80 0.60 3.30 2.99 2.50 TYP. 4.50 1.30 3.00 2.70 0.60 1.20 1.60 1.30 1.70 0.60 15.00 10.16 2.55 5.10 6.70 13.20 1.80 1.00 0.80 3.50 3.19 2.70 5° 4° 10° 5° 5° ITO-220AB(HD) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MAX. 4.70 1.50 3.20 2.90 0.75 1.35 1.75 1.45 1.85 0.75 15.20 10.36 6.90 13.70 2.00 1.20 1.00 3.70 3.39 2.90 MBRF2045CT Technical Data Data Sheet N0828, Rev. A Green Products Marking Diagram: Where XXXXX is YYWWL MBR F 20 45 CT SSG YY WW L = Device Type = Package type = Forward Current (20A) = Reverse Voltage (45V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AB (Pb-Free) MBRF2045CT Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current (per device) Peak One Cycle Non-Repetitive Surge Current (per leg) Symbol VRRM VRWM VR Condition - Max. 45 Units V IF (AV) 50% duty cycle @TC =105°C, rectangular wave form 20 A IFSM 8.3 ms, half Sine pulse 180 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRF2045CT Technical Data Data Sheet N0828, Rev. A Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Reverse Current at DC condition (per leg) * Reverse Current (per leg)* Junction Capacitance (per leg) Series Inductance (per leg) RSM Isolation Voltage (t = 1.0 second, R. H. < =30%, TA = 25 °C) * Symbol VF1 VF2 IR1 IR2 CT LS VISO Condition @ 20A, Pulse, TJ = 25 °C @ 20A, Pulse, TJ = 125 °C Typ. 0.74 0.70 Max. 0.84 0.72 Units V V @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body Clip mounting, the epoxy body away from the heatsink edge by more than 0.110" along the lead direction. Clip mounting, the epoxy body is inside the heatsink. Screw mounting, the epoxy body is inside the heatsink. 0.025 1 mA 9 15.0 mA 250 400 pF 8.0 - nH - 4500 V - 3500 - 1500 Pulse Width < 300µs, Duty Cycle
MBRF2045CT
物料型号: - 型号:MBRF2045CT
器件简介: - MBRF2045CT是一个肖特基整流行波二极管,具有150°C的工作结温,中心抽头配置,低正向电压降,高纯度、耐高温的环氧树脂封装,提高了机械强度和防潮性能,适用于高频操作。
引脚分配: - 文档中提供了引脚的机械尺寸图,但具体的引脚功能未在文本中明确描述。
参数特性: - 最大重复反向电压(VRRM):45V - 工作峰值反向电压(VRWM):45V - DC阻断电压(VR):45V - 平均整流正向电流(IF(AV)):20A(50%占空比,Tc=105°C) - 峰值单周期非重复浪涌电流(IFSM):180A(8.3ms,半正弦脉冲)
功能详解: - MBRF2045CT适用于开关电源、转换器、自由轮二极管和反向电池保护。具有中心抽头配置,用于增强的机械强度和防潮性能,高频率操作能力,以及增强的耐用性和长期可靠性。
应用信息: - 适用于开关电源、转换器、自由轮二极管和反向电池保护。
封装信息: - 封装类型:ITO-220AB(无铅) - 包装:每管50pcs
MBRF2045CT 价格&库存
很抱歉,暂时无法提供与“MBRF2045CT”相匹配的价格&库存,您可以联系我们找货
