MBRF20100CT
MBRF20100CT
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    一对共阴极
MBRF20100CT 数据手册
SANGDEST MICROELECTRONICS MBRF20100CT Green Products Technical Data Data Sheet N0080, Rev. C MBRF20100CT SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 175 ℃ TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request OUTLINE DRAWING Mechanical Dimensions (ln mm) OPTION 1(CJ) ITO-220AB OPTION 2(HD) Dim Min Max Min Max A 4.35 4.65 4.30 4.70 b 0.50 0.75 0.50 0.75 b1 1.15 1.402 1.20 1.45 b2 1.55 1.802 1.60 1.85 b3 1.55 1.65 1.50 1.75 b4 1.10 1.35 1.10 1.35 C 0.50 0.75 0.55 0.75 D 14.8 15.2 14.80 15.20 E 10.06 10.26 9.96 10.36 e 2.46 2.62 F 2.85 3.15 2.80 3.20 G 6.50 6.90 6.50 6.90 L 12.70 13.70 12.70 13.70 L1 3.40 3.80 3.40 4.00 L2 2.60 3.00 - - Q 2.60 2.80 2.50 2.90 Q1 2.50 2.90 2.50 2.90 ØR 3.40 3.60 3.30 3.70 2.55TYP • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRF20100CT Green Products Technical Data Data Sheet N0080, Rev. C Marking Diagram: Where XXXXX is YYWWL MBR F 20 100 CT SSG YY WW L = Device Type = Package type = Forward Current (20A) = Reverse Voltage (100V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AB (Pb-Free) MBRF20100CT Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward Current Max. Peak One Cycle NonRepetitive Surge Current (per leg) Symbol VRWM IF(AV) IFSM Condition 50% duty cycle @TC =133°C, rectangular wave form 8.3 ms, half Sine pulse Max. 100 10(Per leg) 20(Per device) Units V A 150 A • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRF20100CT Green Products Technical Data Data Sheet N0080, Rev. C Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg)* Symbol VF1 VF2 Max. Reverse Current at DC condition (per leg) Max. Reverse Current (per leg)* Repetitive peak reverse current Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change RSM Isolation Voltage (t = 1.0 second, R. H. < =30%, TA = 25 °C) * IR1 IR2 IRRM CT LS dv/dt VISO Condition @ 5A, Pulse, TJ = 25 °C @ 10A, Pulse, TJ = 25 °C @ 5A, Pulse, TJ = 125 °C @ 10A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C tp = 2 µs square F= 1 kHz @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body Clip mounting, the epoxy body away from the heatsink edge by more than 0.110" along the lead direction. Clip mounting, the epoxy body is inside the heatsink. Screw mounting, the epoxy body is inside the heatsink. Max. 0.80 0.90 0.70 0.80 1.0 Units V 6.0 mA 1 A 250 pF 8.0 nH 10,000 4500 V/µs V V mA 3500 1500 Pulse Width < 300µs, Duty Cycle
MBRF20100CT 价格&库存
很抱歉,暂时无法提供与“MBRF20100CT”相匹配的价格&库存,您可以联系我们找货
