MBRF4060CT
MBRF4060CT
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
MBRF4060CT 数据手册
MBRF4060CT Technical Data Data Sheet N0834, Rev. A Green Products MBRF4060CT SCHOTTKY RECTIFIER Applications: • • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Center tap configuration Features: • • • • • • • • • • 150 ℃ TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Terminals: pure tin plated, solderable per MIL-STD-750, Method 2026 This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request OUTLINE DRAWING Mechanical Dimensions: In mm SYMBOL A A1 A2 A3 b b1 b2 b3 b4 c D E e e1 H1 L L1 L2 L3 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Θ5 MIN. 4.30 1.10 2.80 2.50 0.50 1.10 1.50 1.20 1.60 0.55 14.80 9.96 6.50 12.70 1.60 0.80 0.60 3.30 2.99 2.50 TYP. 4.50 1.30 3.00 2.70 0.60 1.20 1.60 1.30 1.70 0.60 15.00 10.16 2.55 5.10 6.70 13.20 1.80 1.00 0.80 3.50 3.19 2.70 5° 4° 10° 5° 5° OPTION1(HD) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MAX. 4.70 1.50 3.20 2.90 0.75 1.35 1.75 1.45 1.85 0.75 15.20 10.36 6.90 13.70 2.00 1.20 1.00 3.70 3.39 2.90 MBRF4060CT Technical Data Data Sheet N0834, Rev. A Green Products OPTION 2 (SR) ITO-220AB • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRF4060CT Technical Data Data Sheet N0834, Rev. A Green Products Marking Diagram: Where XXXXX is YYWWL MBR F 40 60 CT SSG YY WW L = Device Type = Package type = Forward Current (40A) = Reverse Voltage (60V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AB (Pb-Free) MBRF4060CT Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current (per device) Peak One Cycle Non-Repetitive Surge Current (per leg) Symbol VRRM VRWM VR Condition - Max. Units V 60 IF (AV) 50% duty cycle @TC =105°C, rectangular wave form 40 A IFSM 8.3 ms, half Sine pulse 400 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRF4060CT Technical Data Data Sheet N0834, Rev. A Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Reverse Current(per leg)* Junction Capacitance (per leg) Series Inductance (per leg) Voltage Rate of Change * Symbol VF1 VF2 IR1 IR2 IR3 CT LS dv/dt Condition @ 20A, Pulse, TJ = 25 °C @ 20A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 100°C @VR = rated VR TJ = 125°C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Typ. 0.65 0.62 0.1 28 400 Max. 0.75 0.65 1 75 95 900 Units V V mA mA mA pF 8.0 - nH - 10,000 V/μs Specification -55 to +150 -55 to +150 1.5 Units °C °C 50 °C/W 0.50 °C/W 2 g Pulse Width < 300µs, Duty Cycle
MBRF4060CT 价格&库存
很抱歉,暂时无法提供与“MBRF4060CT”相匹配的价格&库存,您可以联系我们找货
