MBRF30100CT
MBRF30100CT
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    一对共阴极
MBRF30100CT 数据手册
MBRF30100CT Technical Data Data Sheet N0851, Rev. B Green Products MBRF30100CT SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150℃ TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request OUTLINE DRAWING Mechanical Dimensions: In mm SYMBOL A A1 A2 A3 b b1 b2 b3 b4 c D E e e1 H1 L L1 L2 L3 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Θ5 MIN. 4.30 1.10 2.80 2.50 0.50 1.10 1.50 1.20 1.60 0.55 14.80 9.96 6.50 12.70 1.60 0.80 0.60 3.30 2.99 2.50 TYP. 4.50 1.30 3.00 2.70 0.60 1.20 1.60 1.30 1.70 0.60 15.00 10.16 2.55 5.10 6.70 13.20 1.80 1.00 0.80 3.50 3.19 2.70 5° 4° 10° 5° 5° ITO-220AB (HD) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MAX. 4.70 1.50 3.20 2.90 0.75 1.35 1.75 1.45 1.85 0.75 15.20 10.36 6.90 13.70 2.00 1.20 1.00 3.70 3.39 2.90 MBRF30100CT Technical Data Data Sheet N0851, Rev. B Green Products Marking Diagram: Where XXXXX is YYWWL MBR F 30 100 CT SSG YY WW L = Device Type = Package type = Forward Current (30A) = Reverse Voltage (100V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AB (Pb-Free) MBRF30100CT Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Average Forward Current(per device) Peak One Cycle NonRepetitive Surge Current (per leg) Symbol VRWM Max. 100 Units V IF(AV) Condition 50% duty cycle @TC = 133°C, rectangular wave form 30 A IFSM 8.3 ms, half Sine pulse 200 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRF30100CT Technical Data Data Sheet N0851, Rev. B Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Reverse Current (per leg) * Symbol VF1 VF2 IR1 IR2 Junction Capacitance (per leg) * CT Condition @ 15 A, Pulse, TJ = 25 °C @ 15 A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Max. 0.85 0.70 Units V V 1.00 mA 15.0 mA 500 pF Specification -55 to +150 -55 to +150 Units °C °C Pulse Width < 300µs, Duty Cycle
MBRF30100CT
物料型号:MBRF30100CT
器件简介:该器件是一款肖特基整流器,适用于开关电源转换器、自由轮二极管和反极性电池保护。
引脚分配:文档中提供了中心抽头的引脚布局图,但未明确列出每个引脚的功能。
参数特性:包括150℃的工作结温、中心抽头配置、低正向电压降、高纯度、高温度环氧封装以增强机械强度和防潮性、高频率操作、增强的护圈以提高耐用性和长期可靠性。此外,这是一个无铅设备,所有SMC部件都可以追溯到晶圆批次。
功能详解:文档中没有提供详细的功能解释,但根据其应用和特性可以推断其功能。
应用信息:适用于开关电源转换器、自由轮二极管和反极性电池保护。
封装信息:ITO-220AB (Pb-Free),50pcs/管,具体胶带和卷轴规格信息需参考胶带和卷轴包装规范。
电气特性和热机械规格也详细列出,包括最大额定值、正向电压降、反向电流、结电容等。此外,还提供了典型的结电容、反向特性和瞬时正向电压特性图表。
MBRF30100CT 价格&库存
很抱歉,暂时无法提供与“MBRF30100CT”相匹配的价格&库存,您可以联系我们找货
