STF20100C
STF20100C
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
STF20100C 数据手册
ST20100C STB20100C STD20100C STF20100C SANGDEST MICROELECTRONICS Technical Data Data Sheet N1045, Rev. B Green Products ST20100C/STB20100C/STD20100C/STF20100C SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150 °C TJ operation Center tap configuration Ultralow forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request ST20100C STB20100C TO-220AB D2PAK Case styles STD20100C DPAK STF20100C ITO-220AB Mechanical Dimensions: In Inches / mm TO-220AB • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • ST20100C STB20100C STD20100C STF20100C SANGDEST MICROELECTRONICS Technical Data Data Sheet N1045, Rev. B Green Products Symbol A A1 A2 b b1 c c1 D D1 E E1 E2 e H L L1 L2 L3 e e1 e2 e3 Dimensions in millimeters Min. Typical Max. 4.55 0 2.59 0.71 0.36 1.17 8.55 6.40 10.01 7.6 9.98 14.6 2.00 1.17 0 4.70 0.10 2.69 0.81 1.27 0.38 1.27 8.70 0.61 1.37 8.85 10.16 10.31 10.08 2.54 15.1 2.30 1.27 10.18 0.25BSC 5° 4° 4° 4.85 0.25 2.89 0.96 15.6 2.70 1.40 2.20 8° D2PAK • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • ST20100C STB20100C STD20100C STF20100C SANGDEST MICROELECTRONICS Technical Data Data Sheet N1045, Rev. B Green Products DPAK • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • ST20100C STB20100C STD20100C STF20100C SANGDEST MICROELECTRONICS Technical Data Data Sheet N1045, Rev. B Green Products SYMBOL A A1 A2 A3 b b1 b2 b3 b4 c D E e e1 H1 L L1 L2 L3 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Θ5 MIN. 4.30 1.10 2.80 2.50 0.50 1.10 1.50 1.20 1.60 0.55 14.80 9.96 6.50 12.70 1.60 0.80 0.60 3.30 2.99 2.50 TYP. 4.50 1.30 3.00 2.70 0.60 1.20 1.60 1.30 1.70 0.60 15.00 10.16 2.55 5.10 6.70 13.20 1.80 1.00 0.80 3.50 3.19 2.70 5° 4° 10° 5° 5° MAX. 4.70 1.50 3.20 2.90 0.75 1.35 1.75 1.45 1.85 0.75 15.20 10.36 6.90 13.70 2.00 1.20 1.00 3.70 3.39 2.90 ITO-220AB • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • ST20100C STB20100C STD20100C STF20100C SANGDEST MICROELECTRONICS Technical Data Data Sheet N1045, Rev. B Green Products Marking Diagram: Where XXXXX is YYWWL ST B/D/F 20 100 C SSG YY WW L ST20100C STB20100C STD20100C = Device Type = Package type = Forward Current (20A) = Reverse Voltage (100V) = Configuration = SSG = Year = Week = Lot Number STF20100C Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package Shipping TO-220AB(Pb-Free) 50pcs / tube STB20100C D²PAK(Pb-Free) 800pcs / reel STD20100C DPAK(Pb-Free) 2500pcs / reel STF20100C ITO-220AB(Pb-Free) 50pcs / tube ST20100C For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Average Forward Current Peak One Cycle Non-Repetitive Surge Current (per leg) Symbol VRWM Max. 100 Units V IF(AV) Condition 50% duty cycle @TC = 95°C, rectangular wave form 20 A IFSM 8.3 ms, half Sine pulse 150 A • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • ST20100C STB20100C STD20100C STF20100C SANGDEST MICROELECTRONICS Technical Data Data Sheet N1045, Rev. B Green Products Electrical Characteristics: Characteristics Forward Voltage Drop * Symbol VF1 VF2 Reverse Current (per leg) IR1 IR2 IR3 Junction Capacitance (per leg) Voltage Rate of Change * CT dv/dt Condition @ 5A, Pulse, TJ = 25 °C @ 10A, Pulse, TJ = 25 °C @ 5A, Pulse, TJ = 125 °C @ 10A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 100 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz - Typ. 0.54 0.69 0.48 0.59 Max. 0.55 0.75 0.53 0.70 Units 18 300 uA - 12 mA 7.8 36 mA 462 - pF - 10,000 V/μs STB20100C STD20100C -55 to +150 -55 to +150 STF20100C Units °C °C 5.5 °C/W 2 g V V Pulse Width < 300µs, Duty Cycle
STF20100C
### 物料型号 - ST20100C - STB20100C - STD20100C - STF20100C
### 器件简介 这些型号均为肖特基整流器,应用于开关电源、变频器、自由轮二极管和反向电池保护。
### 引脚分配 - ST20100C:TO-220AB封装 - STB20100C:D2PAK封装 - STD20100C:DPAK封装 - STF20100C:ITO-220AB封装
### 参数特性 - 工作结温(Tj)最高150℃ - 中心抽头配置 - 超低正向电压降 - 高纯度、耐高温环氧封装,增强机械强度和防潮性能 - 适用于高频操作 - 保护环增强了鲁棒性和长期可靠性 - 无铅设备 - 所有SMC部件都可以追溯到晶圆批次 - 可根据要求提供额外测试
### 功能详解 这些肖特基整流器具有超低正向电压降和高频率操作能力,适用于高效率的电源转换和保护应用。
### 应用信息 - 开关电源 - 变频器 - 自由轮二极管 - 反向电池保护
### 封装信息 - TO-220AB:ST20100C型号使用此封装,具体尺寸包括A、A1、A2、b、b1、C、D、D1、E、e、e1、H1、L、L1等。 - D2PAK:STB20100C型号使用此封装,具体尺寸包括A、A1、A2、b、b1、C、c1、D、D1、E、E1、E2、e、H、L、L1、L2、L3等。 - DPAK:STD20100C型号使用此封装。 - ITO-220AB:STF20100C型号使用此封装。
STF20100C 价格&库存
很抱歉,暂时无法提供与“STF20100C”相匹配的价格&库存,您可以联系我们找货
