MBR30150CT
MBRB30150CT
MBR30150CT-1
SANGDEST
MICROELECTRONICS
Green Products
Technical Data
Data Sheet N0767, Rev. A
MBR30150CT/MBRB30150CT/MBR30150CT-1
SCHOTTKY RECTIFIER
Applications:
Switching power supply
Converters
Free-Wheeling diodes
Reverse battery protection
Features:
150 °C TJ operation
Center tap configuration
Low forward voltage drop
High purity, high temperature epoxy encapsulation for enhanced mechanical strength and
moisture resistance
High frequency operation
Guard ring for enhanced ruggedness and long term reliability
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
MBR30…CT
Case styles
MBRB30…CT
MBR30…CT-1
TO-220AB
D2PAK
TO-262
Mechanical Dimensions: In Inches / mm
TO-220AB
• Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113
(86) 25-87123907 •
• FAX (86) 25-87123900 • World Wide Web Site - http:// www.smc-diodes.com • E-Mail Address - sales@ smc-diodes.com •
MBR30150CT
MBRB30150CT
MBR30150CT-1
SANGDEST
MICROELECTRONICS
Green Products
Technical Data
Symbol
A
A1
A2
b
b1
c
c1
D
D1
E
E1
E2
e
H
L
L1
L2
L3
e
e1
e2
e3
D2PAK
Dimensions in
millimeters
Min. Typical Max.
4.55
0.71
0.36
1.17
8.55
6.40
10.01
7.6
9.98
14.6
2.00
1.17
0.10
2.69
0.81
1.27
0.38
1.27
8.70
4.85
0.25
2.89
0.96
10.16
10.31
10.08
2.54
15.1
2.30
1.27
10.18
0.25BSC
5°
4°
4°
0.61
1.37
8.85
15.6
2.70
1.40
2.20
8°
TO-262
(86) 25-87123907 •
MBR30150CT
MBRB30150CT
MBR30150CT-1
SANGDEST
MICROELECTRONICS
Green Products
Technical Data
Marking Diagram:
Where XXXXX is YYWWL
MBR
B
30
150
CT/CT-1
SSG
YY
WW
L
MBR30150CT
= Device Type
= Package type
= Forward Current (30A)
= Reverse Voltage (150V)
= Configuration
= SSG
= Year
= Week
= Lot Number
MBRB30150CT
Cautions:Molding resin
Epoxy resin UL:94V-0
Ordering Information:
Device
Package
TO-220AB
(Pb-Free)
D²PAK
(Pb-Free)
MBR30150CT
MBRB30150CT
Shipping
50pcs / tube
800pcs / reel
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
Maximum Ratings:
Characteristics
Peak Inverse Voltage
Symbol
VRWM
Average Forward Current
IF(AV)
Condition
50% duty cycle @TC = 103°C,
rectangular wave form
Peak One Cycle
Non-Repetitive Surge Current
(per leg)
IFSM
8.3 ms, half Sine pulse
Max.
150
Units
V
30
A
200
A
(86) 25-87123907 •
MBR30150CT
MBRB30150CT
MBR30150CT-1
SANGDEST
MICROELECTRONICS
Green Products
Technical Data
Electrical Characteristics:
Characteristics
Forward Voltage Drop
(per leg) *
Reverse Current (per leg) *
Symbol
VF1
VF2
IR1
IR2
Junction Capacitance
(per leg)
Typical Series Inductance
(per leg)
Max. Voltage Rate of Change
CT
LS
dv/dt
Condition
@ 15 A, Pulse, TJ = 25 °C
@ 15 A, Pulse, TJ = 125 °C
@VR = rated VR
TJ = 25 °C
@VR = rated VR
TJ = 125 °C
@VR = 5V, TC = 25 °C
fSIG = 1MHz
Measured lead to lead 5 mm from
package body
Condition
Max.
1.00
0.80
1.0
Units
V
V
mA
6.0
mA
400
pF
8.0
nH
10,000
V/µs
Specification
-55 to +150
-55 to +150
Units
°C
°C
Pulse Width < 300µs, Duty Cycle
很抱歉,暂时无法提供与“MBR30150CT”相匹配的价格&库存,您可以联系我们找货
