STF2045C
STF2045C
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
STF2045C 数据手册
ST2045C STB2045C STF2045C STD2045C Technical Data Data Sheet N1035, Rev. A Green Products ST2045C/STB2045C/STF2045C/STD2045C SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150 °C TJ operation Center tap configuration Ultralow forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Trench MOS Schottky technology This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Case styles ST2045C TO-220AB STB2045C STF2045C ITO-220AB D2PAK Mechanical Dimensions: In Inches / mm STD2045C DPAK TO-220AB • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • ST2045C STB2045C STF2045C STD2045C Technical Data Data Sheet N1035, Rev. A Green Products Symbol A A1 A2 b b1 c c1 D D1 E E1 E2 e H L L1 L2 L3 e e1 e2 e3 Dimensions in millimeters Min. Typical Max. 4.55 0 2.59 0.71 0.36 1.17 8.55 6.40 10.01 7.6 9.98 14.6 2.00 1.17 0 4.70 0.10 2.69 0.81 1.27 0.38 1.27 8.70 0.61 1.37 8.85 10.16 10.31 10.08 2.54 15.1 2.30 1.27 10.18 0.25BSC 5° 4° 4° 4.85 0.25 2.89 0.96 15.6 2.70 1.40 2.20 8° D2PAK • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • ST2045C STB2045C STF2045C STD2045C Technical Data Data Sheet N1035, Rev. A Green Products SYMBOL A A1 A2 A3 b b1 b2 b3 b4 c D E e e1 H1 L L1 L2 L3 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Θ5 MIN. 4.30 1.10 2.80 2.50 0.50 1.10 1.50 1.20 1.60 0.55 14.80 9.96 6.50 12.70 1.60 0.80 0.60 3.30 2.99 2.50 TYP. 4.50 1.30 3.00 2.70 0.60 1.20 1.60 1.30 1.70 0.60 15.00 10.16 2.55 5.10 6.70 13.20 1.80 1.00 0.80 3.50 3.19 2.70 5° 4° 10° 5° 5° MAX. 4.70 1.50 3.20 2.90 0.75 1.35 1.75 1.45 1.85 0.75 15.20 10.36 6.90 13.70 2.00 1.20 1.00 3.70 3.39 2.90 ITO-220AB • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • ST2045C STB2045C STF2045C STD2045C Technical Data Data Sheet N1035, Rev. A Green Products DPAK • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • ST2045C STB2045C STF2045C STD2045C Technical Data Data Sheet N1035, Rev. A Green Products Marking Diagram: Where XXXXX is YYWWL ST B/F/D 20 45 C SSG YY WW L ST2045C STB2045C STF2045C = Device Type = Package type = Forward Current (20A) = Reverse Voltage (45V) = Configuration = SSG = Year = Week = Lot Number STD2045C Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package Shipping TO-220AB(Pb-Free) 50pcs / tube STB2045C D²PAK(Pb-Free) 800pcs / reel STF2045C ITO-220AB(Pb-Free) 50pcs / tube STD2045C DPAK(Pb-Free) 2500pcs / reel ST2045C For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Forward Current Peak One Cycle Non-Repetitive Surge Current (per leg) Symbol VRRM VRWM VR Condition - IF(AV) 50% duty cycle @TC = 80°C, rectangular wave form IFSM 8.3 ms, half Sine pulse Max. Units 45 V 20 A 150 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • ST2045C STB2045C STF2045C STD2045C Technical Data Data Sheet N1035, Rev. A Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg)* Reverse Current (per leg)* Symbol VF1 VF2 IR1 IR2 * Condition @ 10A, Pulse, TJ = 25 °C @ 10A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C Max. 0.58 0.52 Units V V 2 mA 30 mA Specification -55 to +150 -55 to +150 Units °C °C 6.5 °C/W Pulse Width < 300µs, Duty Cycle
STF2045C
物料型号包括ST2045C、STB2045C、STF2045C和STD2045C,这些是肖特基整流器,应用于开关电源、转换器、自由轮流通二极管和反向电池保护。
器件简介:这些肖特基整流器采用沟槽MOS肖特基技术,具有150°C的工作结温、超低正向电压降、高纯度、高温度环氧封装,增强了机械强度和防潮性,并且是无铅设备。
引脚分配:ST2045C和STF2045C为双引脚配置,STB2045C和STD2045C为单引脚配置。
参数特性:包括最大反向重复峰值电压45V、平均正向电流20A、正向电压降在25°C时为0.58V、在125°C时为0.52V、反向电流在25°C时为2mA、在125°C时为30mA。
功能详解:这些器件适用于高频开关,由于超低正向电压降,它们有助于提高能效。
应用信息:适用于需要高效率和高可靠性的电源转换场合,如开关电源和电池保护。
封装信息:ST2045C采用TO-220AB封装,STB2045C采用D2PAK封装,STF2045C采用ITO-220AB封装,STD2045C采用DPAK封装。
封装均为无铅版本,具体尺寸和重量在文档中有详细描述。
STF2045C 价格&库存
很抱歉,暂时无法提供与“STF2045C”相匹配的价格&库存,您可以联系我们找货
