SANGDEST
MICROELECTRONICS
MBR4045CT
Technical Data
Data Sheet N0743, Rev. -
Green Products
MBR4045CT SCHOTTKY RECTIFIER
Applications:
Switching power supply
Converters
Free-Wheeling diodes
Reverse battery protection
Features:
150 °C TJ operation
Center tap configuration
Low forward voltage drop
High purity, high temperature epoxy encapsulation for enhanced
mechanical strength and moisture resistance
High frequency operation
Guard ring for enhanced ruggedness and long term reliability
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
Mechanical Dimensions: In mm
Symbol
A
A1
A2
b
b1
c
D
D1
E
e
e1
H1
L
L1
ΦP
Q
Θ1
Θ2
Θ3
Dimensions in
millimeters
Min
Typical
Max
4.42
4.57
4.72
1.17
1.27
1.37
2.59
2.69
2.89
0.71
0.81
0.96
1.27
0.36
0.38
0.61
14.94
15.24
15.54
8.85
9.00
9.15
10.01
10.16
10.31
2.54
5.06
6.04
6.24
6.44
12.7
13.56
13.78
3.5
3.74
3.84
4.04
2.54
2.74
2.94
7°
3°
4°
OPTION 1(HD)
• Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113 (86) 25-87123907 •
• FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn •
SANGDEST
MICROELECTRONICS
MBR4045CT
Technical Data
Green Products
OPTION 2(SR)
TO-220AB
SANGDEST
MICROELECTRONICS
MBR4045CT
Technical Data
Green Products
Marking Diagram:
Where XXXXX is YYWWL
MBR
40
45
CT
SSG
YY
WW
L
= Device Type
= Forward Current (40A)
= Reverse Voltage (45V)
= Configuration
= SSG
= Year
= Week
= Lot Number
Cautions:Molding resin
Epoxy resin UL:94V-0
Ordering Information:
Device
Package
TO-220AB
(Pb-Free)
MBR4045CT
Shipping
50pcs / tube
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
Maximum Ratings:
Characteristics
Peak Inverse Voltage
Max. Average Forward
Peak Repetitive Forward
Current (per leg)
Max. Peak One Cycle NonRepetitive Surge Current
(per leg)
Symbol
VRWM
IF(AV)
Condition
@TC = 118°C, Rated VR
IFRM
Square wave, 20kHz
IFSM
8.3 ms, half Sine pulse
Max.
45
20(per leg)
Units
V
A
40(per device)
40
A
252
A
SANGDEST
MICROELECTRONICS
MBR4045CT
Technical Data
Green Products
Electrical Characteristics:
Characteristics
Max. Forward Voltage Drop
(per leg) *
Symbol
VF1
VF2
Max. Reverse Current
(per leg) *
Max. Junction Capacitance
(per leg)
Typical Series Inductance
(per leg)
Max. Voltage Rate of Change
IR1
IR2
IR3
CT
LS
dv/dt
Condition
@ 20A, Pulse, TJ = 25 °C
@ 40A, Pulse, TJ = 25 °C
@ 20A, Pulse, TJ = 125 °C
@ 40A, Pulse, TJ = 125 °C
@VR = rated VR TJ = 25 °C
@VR = rated VR TJ = 100°C
@VR = rated VR TJ = 125°C
@VR = 5V, TC = 25 °C
fSIG = 1MHz
Measured lead to lead 5 mm from
package body
Max.
0.60
0.78
0.58
0.75
1
50
95
900
Units
V
8.0
nH
10,000
V/μs
V
mA
mA
mA
pF
Pulse Width < 300µs, Duty Cycle
很抱歉,暂时无法提供与“MBR4045CT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+20.389521+2.63189
