MBRF40100CT
MBRF40100CT
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    特性:150℃结温工作。 中心抽头配置。 低正向压降。 高纯度、高温环氧树脂封装,增强机械强度和防潮性。 高频工作。 保护环,增强耐用性和长期可靠性。应用:开关电源。 转换器
MBRF40100CT 数据手册
MBRF4080CT MBRF4090CT MBRF40100CT Technical Data Data Sheet N0083, Rev. B Green Products MBRF4080CT/MBRF4090CT/MBRF40100CT SCHOTTKY RECTIFIER Applications: • • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Center tap configuration Features: • • • • • • • • • 150°C TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request OUTLINE DRAWING Mechanical Dimensions: In Inches / mm OPTION 1(CJ) OPTION 2(HD) Dim Min Max Min Max A 4.4 4.6 4.30 4.70 b 0.6TYP 0.50 0.75 b1 1.3TYP 1.30 1.40 b2 1.7TYP 1.70 1.80 b3 1.6TYP 1.50 1.75 b4 1.2TYP 1.10 1.35 C 0.60TYP 0.50 0.75 D 14.8 15.1 14.80 15.20 E 10.06 10.26 9.96 10.36 e 2.55TYP 2.54TYP F 2.9 3.1 2.80 3.20 G 6.5 6.9 6.50 6.90 L 12.7 13.7 12.8 13.2 L1 3.4 3.8 3.60 4.00 L2 2.6 3.0 - - Q 2.5 2.9 2.50 2.90 Q1 2.5 2.9 ØR 3.5REF 2.70REF 3.50REF • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRF4080CT MBRF4090CT MBRF40100CT Technical Data Data Sheet N0083, Rev. B Green Products OPTION 3 (SR) ITO-220AB • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRF4080CT MBRF4090CT MBRF40100CT Technical Data Data Sheet N0083, Rev. B Green Products Marking Diagram: Where XXXXX is YYWWL MBR F 40 80 CT SSG YY WW L = Device Type = Package type = Forward Current (40A) = Reverse Voltage (80V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device MBRF4080CT MBRF4090CT MBRF40100CT Package Shipping ITO-220AB (Pb-Free) 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Symbol VRWM Condition - Average Forward Current IF(AV) 50% duty cycle @TC =135°C, rectangular wave form Peak One Cycle NonRepetitive Surge Current (per leg) IFSM 8.3 ms, half Sine pulse 80 90 100 Max. MBRF4080CT MBRF4090CT MBRF40100CT 20(Per leg) 40(Per device) 280 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • Units V A A MBRF4080CT MBRF4090CT MBRF40100CT Technical Data Data Sheet N0083, Rev. B Green Products Electrical Characteristics: Characteristics Forward Voltage Drop* Symbol VF1 VF2 Reverse Current (per leg)* IR1 IR2 Junction Capacitance (per leg) Typical Series Inductance (per leg) Voltage Rate of Change RSM Isolation Voltage (t = 1.0 second, R. H. < =30%, TA = 25 °C) * CT LS dv/dt VISO Condition @ 10A, Pulse, TJ = 25 °C @ 20A, Pulse, TJ = 25 °C @ 10A, Pulse, TJ = 125 °C @ 20A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body Clip mounting, the epoxy body away from the heatsink edge by more than 0.110" along the lead direction. Clip mounting, the epoxy body is inside the heatsink. Screw mounting, the epoxy body is inside the heatsink. Typ. 0.70 0.80 0.59 0.70 0.009 Max. 0.80 0.88 0.70 0.74 1.0 Units V 6.4 20 mA 363 400 pF - 8.0 nH - 10,000 4500 V/μs V - 3500 - 1500 V mA Pulse Width < 300µs, Duty Cycle
MBRF40100CT 价格&库存
很抱歉,暂时无法提供与“MBRF40100CT”相匹配的价格&库存,您可以联系我们找货
