MBRF40100CTR
MBRF40100CTR
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
MBRF40100CTR 数据手册
MBRF40100CTR Technical Data Data Sheet N0856, Rev. A Green Products MBRF40100CTR SCHOTTKY RECTIFIER Applications: • • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Center tap configuration Features: • • • • • • • • • 150°C TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request OUTLINE DRAWING Mechanical Dimensions: In mm SYMBOL A A1 A2 A3 b b1 b2 b3 b4 c D E e e1 H1 L L1 L2 L3 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Θ5 MIN. 4.30 1.10 2.80 2.50 0.50 1.10 1.50 1.20 1.60 0.55 14.80 9.96 6.50 12.70 1.60 0.80 0.60 3.30 2.99 2.50 TYP. 4.50 1.30 3.00 2.70 0.60 1.20 1.60 1.30 1.70 0.60 15.00 10.16 2.55 5.10 6.70 13.20 1.80 1.00 0.80 3.50 3.19 2.70 5° 4° 10° 5° 5° ITO-220AB (HD) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MAX. 4.70 1.50 3.20 2.90 0.75 1.35 1.75 1.45 1.85 0.75 15.20 10.36 6.90 13.70 2.00 1.20 1.00 3.70 3.39 2.90 MBRF40100CTR Technical Data Data Sheet N0856, Rev. A Green Products Marking Diagram: Where XXXXX is YYWWL MBR F 40 100 CTR SSG YY WW L = Device Type = Package type = Forward Current (40A) = Reverse Voltage (100V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package ITO-220AB (Pb-Free) MBRF40100CTR Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Average Forward Current Symbol VRWM IF(AV) Peak One Cycle NonRepetitive Surge Current (per leg) IFSM Condition 50% duty cycle @TC =135°C, rectangular wave form Max. 100 Units V 40 A 8.3 ms, half Sine pulse 280 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRF40100CTR Technical Data Data Sheet N0856, Rev. A Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg)* Reverse Current (per leg)* Symbol VF1 VF2 IR1 IR2 Junction Capacitance (per leg) Typical Series Inductance (per leg) Voltage Rate of Change RSM Isolation Voltage (t = 1.0 second, R. H. < =30%, TA = 25 °C) * CT LS dv/dt VISO Condition @ 20A, Pulse, TJ = 25 °C @ 20A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body Clip mounting, the epoxy body away from the heatsink edge by more than 0.110" along the lead direction. Clip mounting, the epoxy body is inside the heatsink. Screw mounting, the epoxy body is inside the heatsink. Max. 0.88 0.74 Units V V 1.0 mA 20 mA 400 pF 8.0 nH 10,000 V/μs 4500 V 3500 1500 Pulse Width < 300µs, Duty Cycle
MBRF40100CTR 价格&库存
很抱歉,暂时无法提供与“MBRF40100CTR”相匹配的价格&库存,您可以联系我们找货
