MBR40100CT
MBR40100CT
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    一对共阴极
MBR40100CT 数据手册
MBR4080/90/100CT Technical Data Data Sheet N0771, Rev. B Green Products MBR4080/90/100CT SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150 °C TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm Symbol A A1 A2 b b1 c D D1 E e e1 H1 L L1 ΦP Q Θ1 Θ2 Θ3 Dimensions in millimeters Min Typical Max 4.42 4.57 4.72 1.17 1.27 1.37 2.59 2.69 2.89 0.71 0.81 0.96 1.27 0.36 0.38 0.61 14.94 15.24 15.54 8.85 9.00 9.15 10.01 10.16 10.31 2.54 5.06 6.04 6.24 6.44 12.7 13.56 13.78 3.5 3.74 3.84 4.04 2.54 2.74 2.94 7° 3° 4° OPTION 1(HD) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR4080/90/100CT Technical Data Data Sheet N0771, Rev. B Green Products OPTION 2(SR) TO-220AB • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR4080/90/100CT Technical Data Data Sheet N0771, Rev. B Green Products Marking Diagram: Where XXXXX is YYWWL MBR 40 100 CT SSG YY WW L = Device Type = Forward Current (40A) = Reverse Voltage (100V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package TO-220AB (Pb-Free) MBR40100CT Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Forward Current(per device) Peak One Cycle Non-Repetitive Surge Current (per leg) Symbol VRRM VRWM VR IF(AV) IFSM Condition - 50% duty cycle @TC = 110°C, rectangular wave form 8.3 ms, half Sine pulse 80 90 100 Max. MBR4080CT MBR4090CT MBR40100CT 40 250 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • Units V A A MBR4080/90/100CT Technical Data Data Sheet N0771, Rev. B Green Products Electrical Characteristics: Characteristics Forward Voltage Drop(per leg) * Reverse Current (per leg) * Symbol VF1 VF2 IR1 IR2 Junction Capacitance (per leg) Voltage Rate of Change * CT dv/dt Condition @ 20 A, Pulse, TJ = 25 °C @ 20 A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz - Max. 0.88 0.74 1.0 Units V V mA 20 mA 800 pF 10,000 V/μs Specification -55 to +150 -55 to +150 2.0 Units °C °C 2 g Pulse Width < 300µs, Duty Cycle
MBR40100CT 价格&库存
很抱歉,暂时无法提供与“MBR40100CT”相匹配的价格&库存,您可以联系我们找货
MBR40100CT
  • 1+21.059211+2.73670
  • 10+13.4838710+1.75227
  • 50+10.2145750+1.32741
  • 100+9.15959100+1.19032
  • 500+7.30740500+0.94962
库存:869
