STF30150C
STF30150C
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
STF30150C 数据手册
SANGDEST MICROELECTRONICS STF30150C(R) Technical Data Data Sheet N1402, Rev. A Green Products STF30150C(R) SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150 °C TJ operation Center tap configuration Ultralow forward voltage drop STF30150C High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request STF30150CR Mechanical Dimensions: In mm SYMBOL A A1 A2 A3 b b1 b2 b3 b4 c D E e e1 H1 L L1 L2 L3 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Θ5 MIN. 4.30 1.10 2.80 2.50 0.50 1.10 1.50 1.20 1.60 0.55 14.80 9.96 6.50 12.70 1.60 0.80 0.60 3.30 2.99 2.50 TYP. 4.50 1.30 3.00 2.70 0.60 1.20 1.60 1.30 1.70 0.60 15.00 10.16 2.55 5.10 6.70 13.20 1.80 1.00 0.80 3.50 3.19 2.70 5° 4° 10° 5° 5° MAX. 4.70 1.50 3.20 2.90 0.75 1.35 1.75 1.45 1.85 0.75 15.20 10.36 6.90 13.70 2.00 1.20 1.00 3.70 3.39 2.90 ITO-220AB • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS STF30150C(R) Technical Data Data Sheet N1402, Rev. A Green Products Marking Diagram: Where XXXXX is YYWWL S T F 30 150 C(R) SSG YY WW L STF30150C = Device Type = Ultralow VF = Package type = Forward Current (30A) = Reverse Voltage (150V) = Configuration = SSG = Year = Week = Lot Number STF30150CR Cautions:Molding resin Epoxy resin UL: 94V-0 Ordering Information: Device Package ITO-220AB (Pb-Free) STF30150C(R) Shipping 50pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Symbol VRWM Condition - Max. 150 Units V Average Forward Current IF(AV) 50% duty cycle @TC =100°C rectangular wave form 30 A Peak One Cycle NonRepetitive Surge Current (per leg) IFSM 8.3 ms, half Sine pulse 200 A • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS STF30150C(R) Technical Data Data Sheet N1402, Rev. A Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg)* Symbol VF1 VF2 Reverse Current (per leg) Reverse Current (per leg) * Junction Capacitance (per leg) RSM Isolation Voltage (t = 1.0 second, R. H. < =30%, TA = 25 °C) IR1 IR2 CT VISO * Condition @ 5A, Pulse, TJ = 25 °C @ 7.5A, Pulse, TJ = 25 °C @ 15A, Pulse, TJ = 25 °C @ 5A, Pulse, TJ = 125 °C @ 7.5A, Pulse, TJ = 125 °C @ 15A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Clip mounting, the epoxy body away from the heatsink edge by more than 0.110" along the lead direction. Clip mounting, the epoxy body is inside the heatsink. Screw mounting, the epoxy body is inside the heatsink. Typ. 0.66 0.79 1.16 0.56 0.62 0.74 Max. 1.36 0.79 Units 0.006 0.2 mA 2.6 20 mA 670 - pF - 4500 - 3500 - 1500 V V V Pulse Width < 300µs, Duty Cycle
STF30150C
物料型号:STF30150C(R)
器件简介:STF30150C(R) 是一款肖特基整流器,适用于开关电源、转换器、自由轮转二极管和反电池保护。
引脚分配:1. 阴极 2. 阳极 3. 阴极
参数特性: - 最大反向工作电压:150V - 平均正向电流:30A - 峰值单周期非重复浪涌电流:200A - 正向电压降:在5A、7.5A、15A电流下分别为0.66V、0.79V、1.16V - 反向电流:在25°C和125°C下分别为0.006mA和2.6mA - 结电容:在5V反向电压下为670pF - 隔离电压:根据安装方式不同,分别为4500V、3500V和1500V
功能详解:STF30150C(R) 具有150°C的工作温度,中心抽头配置,超低正向电压降,高纯度、耐高温环氧树脂封装,增强机械强度和防潮性能,适用于高频操作,具有增强的鲁棒性和长期可靠性。
应用信息:STF30150C(R) 适用于开关电源、转换器、自由轮转二极管和反电池保护。
封装信息:ITO-220AB,50pcs/管装。
以上信息摘自STF30150C(R)的技术数据手册。
STF30150C 价格&库存
很抱歉,暂时无法提供与“STF30150C”相匹配的价格&库存,您可以联系我们找货
