STF30100C
STF30100C
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    DIODEARRAYSCHOTTKY100VITO220
STF30100C 数据手册
ST30100C STB30100C STF30100C Technical Data Data Sheet N1047, Rev. B Green Products ST30100C/STB30100C/STF30100C SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150 °C TJ operation Center tap configuration Ultralow forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Trench MOS Schottky technology This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request ST30100C TO-220AB Case styles STB30100C D2PAK Mechanical Dimensions: In Inches / mm STF30100C ITO-220AB TO-220AB • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • ST30100C STB30100C STF30100C Technical Data Data Sheet N1047, Rev. B Green Products Symbol A A1 A2 b b1 c c1 D D1 E E1 E2 e H L L1 L2 L3 e e1 e2 e3 Dimensions in millimeters Min. Typical Max. 4.55 0 2.59 0.71 0.36 1.17 8.55 6.40 10.01 7.6 9.98 14.6 2.00 1.17 0 4.70 0.10 2.69 0.81 1.27 0.38 1.27 8.70 0.61 1.37 8.85 10.16 10.31 10.08 2.54 15.1 2.30 1.27 10.18 0.25BSC 5° 4° 4° 4.85 0.25 2.89 0.96 15.6 2.70 1.40 2.20 8° D2PAK • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • ST30100C STB30100C STF30100C Technical Data Data Sheet N1047, Rev. B Green Products SYMBOL A A1 A2 A3 b b1 b2 b3 b4 c D E e e1 H1 L L1 L2 L3 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Θ5 MIN. 4.30 1.10 2.80 2.50 0.50 1.10 1.50 1.20 1.60 0.55 14.80 9.96 6.50 12.70 1.60 0.80 0.60 3.30 2.99 2.50 TYP. 4.50 1.30 3.00 2.70 0.60 1.20 1.60 1.30 1.70 0.60 15.00 10.16 2.55 5.10 6.70 13.20 1.80 1.00 0.80 3.50 3.19 2.70 5° 4° 10° 5° 5° MAX. 4.70 1.50 3.20 2.90 0.75 1.35 1.75 1.45 1.85 0.75 15.20 10.36 6.90 13.70 2.00 1.20 1.00 3.70 3.39 2.90 ITO-220AB • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • ST30100C STB30100C STF30100C Technical Data Data Sheet N1047, Rev. B Green Products Marking Diagram: Where XXXXX is YYWWL ST B/F 30 100 C SSG YY WW L ST30100C STB30100C = Device Type = Package type = Forward Current (30A) = Reverse Voltage (100V) = Configuration = SSG = Year = Week = Lot Number STF30100C Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package Shipping TO-220AB(Pb-Free) 50pcs / tube STB30100C D²PAK(Pb-Free) 800pcs / reel STF30100C ITO-220AB(Pb-Free) 50pcs / tube ST30100C For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Symbol VRRM VRWM VR Condition - Average Forward Current IF(AV) 50% duty cycle @TC =100°C, rectangular wave form Peak One Cycle Non-Repetitive Surge Current(per leg) IFSM 8.3 ms, half Sine pulse Max. Units 100 V 30 A 200 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • ST30100C STB30100C STF30100C Technical Data Data Sheet N1047, Rev. B Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg)* Reverse Current (per leg)* Symbol VF1 VF2 IR1 IR2 Junction Capacitance (per leg) * CT Condition @ 15A, Pulse, TJ = 25 °C @ 15A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Typ. 0.70 0.67 Max. 0.75 0.70 Units V V 0.023 0.5 mA 13 35 mA 686 - pF Pulse Width < 300µs, Duty Cycle
STF30100C
物料型号: - ST30100C - STB30100C - STF30100C
器件简介: 这些是肖特基整流器,适用于开关电源、转换器、续流二极管和反极性电池保护等应用。
引脚分配: - ST30100C和STF30100C采用TO-220AB封装,STB30100C采用D2PAK封装。
参数特性: - 工作结温范围为-55°C至+150°C。 - 存储温度范围为-55°C至+150°C。 - 典型热阻从结到外壳分别为2.5°C/W(ST30100C和STB30100C)、5.5°C/W(STF30100C)。 - 重量分别为2.0g(ST30100C和STF30100C)、1.85g(STB30100C)。
功能详解: - 这些器件采用沟槽MOS肖特基技术,具有超低正向电压降、高纯度、高温度下环氧树脂封装,增强了机械强度和防潮性,适合高频操作。
应用信息: - 适用于需要高效率和高可靠性的电源转换和电池保护应用。
封装信息: - 提供TO-220AB、D2PAK和ITO-220AB三种封装方式。
STF30100C 价格&库存
很抱歉,暂时无法提供与“STF30100C”相匹配的价格&库存,您可以联系我们找货
