MBR30100WT
Technical Data
Data Sheet N0040, Rev. B
Green Products
MBR30100WT SCHOTTKY RECTIFIER
Applications:
Switching power supply
Converters
Free-Wheeling diodes
Reverse battery protection
Center tap configuration
Features:
150 °C TJ operation
Low forward voltage drop
High purity, high temperature epoxy encapsulation for enhanced
mechanical strength and moisture resistance
High frequency operation
Guard ring for enhanced ruggedness and long term reliability
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
ANODE 1
ANODE 2
1
3
2
COMMON
CATHODE
BASE
Mechanical Dimensions: In mm/Inches
SYMBOL
A
A1
A2
b
b1
b2
c
D
D1
D2
E
E1
E2
E3
e
L
L1
P
P1
P2
Q
S
T
U
MIN.
4.80
2.21
1.90
1.10
0.55
20.80
15.60
19.42
3.50
6.05
TYP.
5.00
2.41
2.00
1.20
2.00
3.00
0.60
21.00
16.55
1.20
15.80
13.30
5.00
2.50
5.44
19.92
4.13
3.60
2.50
5.80
6.15
10.00
6.20
OPTION 1(HD)
• China - Germany - Korea - Singapore - United States •
• http://www.smc-diodes.com - sales@ smc-diodes.com •
MAX.
5.20
2.61
2.10
1.35
0.75
21.20
16.00
20.42
3.70
7.40
6.25
MBR30100WT
Technical Data
Green Products
OPTION 2(CJ)
TO-247AD
MBR30100WT
Technical Data
Green Products
Marking Diagram:
Where XXXXX is YYWWL
MBR
30
100
WT
SSG
YY
WW
L
= Device Type
= Forward Current (30A)
= Reverse Voltage (100V)
= Configuration
= SSG
= Year
= Week
= Lot Number
Cautions:Molding resin
Epoxy resin UL:94V-0
Ordering Information:
Device
MBR30100WT
Package
Shipping
TO-247AD (Pb-Free)
30pcs/ tube
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging
Specification.
Maximum Ratings:
Characteristics
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
Average Rectified Forward
Current(per device)
Peak Repetitive Forward
Current(per leg)
Peak One Cycle Non-Repetitive
Surge Current(per leg)
Symbol
VRRM
VRWM
VR
IF (AV)
IFRM
IFSM
Condition
Max.
Units
V
100
50% duty cycle @TC =103°C,
rectangular wave form
Rated VR square wave,
20KHz TC =133°C
8.3 ms, half Sine pulse
30
A
A
150
A
MBR30100WT
Technical Data
Green Products
Electrical Characteristics:
Characteristics
Forward Voltage Drop
(per leg)*
Symbol
VF1
VF2
Reverse Current (per leg) *
IR1
IR2
Junction Capacitance
(per leg)
Series Inductance
(per leg)
Voltage Rate of Change
CT
LS
dv/dt
Condition
@ 15A, Pulse, TJ = 25 °C
@ 30 A, Pulse, TJ = 25 °C
@ 15 A, Pulse, TJ = 125 °C
@ 30 A, Pulse, TJ = 125 °C
@VR = rated VR
TJ = 25 °C
@VR = rated VR
TJ = 125 °C
@VR = 5V, TC = 25 °C
fSIG = 1MHz
Measured lead to lead 5 mm
from package body
Typ.
0.78
0.90
0.65
0.77
Max.
0.85
1.05
0.70
0.85
Units
0.003
1.0
mA
2
15.0
mA
380
500
pF
8.0
nH
10,000
V/μs
Specification
-55 to +150
-55 to +150
2.0
Units
°C
°C
°C/W
50
°C/W
0.50
°C/W
6.7
g
V
V
Pulse Width < 300µs, Duty Cycle
很抱歉,暂时无法提供与“MBR30100WT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+24.658351+3.18708
- 25+13.5595425+1.75256
- 100+10.89269100+1.40787
- 500+8.75308500+1.13133
- 1000+8.065231000+1.04243
- 2000+7.486922000+0.96768
- 5000+6.861475000+0.88684
- 10000+6.6081710000+0.85410
