STF4045C
STF4045C
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    DIODE ARRAY SCHOTTKY 45V ITO220
STF4045C 数据手册
ST4045C STB4045C STF4045C SANGDEST MICROELECTRONICS Technical Data Data Sheet N1447, Rev. A Green Products ST4045C/STB4045C/STF4045C SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150 °C TJ operation Center tap configuration Ultralow forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request ST4045C Case styles STB4045C STF4045C TO-220AB D2PAK ITO-220AB Mechanical Dimensions: In Inches / mm TO-220AB • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • ST4045C STB4045C STF4045C SANGDEST MICROELECTRONICS Technical Data Data Sheet N1447, Rev. A Green Products Symbol A A1 A2 b b1 c c1 D D1 E E1 E2 e H L L1 L2 L3 e e1 e2 e3 Dimensions in millimeters Min. Typical Max. 4.55 0 2.59 0.71 0.36 1.17 8.55 6.40 10.01 7.6 9.98 14.6 2.00 1.17 0 4.70 0.10 2.69 0.81 1.27 0.38 1.27 8.70 0.61 1.37 8.85 10.16 10.31 10.08 2.54 15.1 2.30 1.27 10.18 0.25BSC 5° 4° 4° 4.85 0.25 2.89 0.96 15.6 2.70 1.40 2.20 8° D2PAK • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • ST4045C STB4045C STF4045C SANGDEST MICROELECTRONICS Technical Data Data Sheet N1447, Rev. A Green Products SYMBOL A A1 A2 A3 b b1 b2 b3 b4 c D E e e1 H1 L L1 L2 L3 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Θ5 MIN. 4.30 1.10 2.80 2.50 0.50 1.10 1.50 1.20 1.60 0.55 14.80 9.96 6.50 12.70 1.60 0.80 0.60 3.30 2.99 2.50 TYP. 4.50 1.30 3.00 2.70 0.60 1.20 1.60 1.30 1.70 0.60 15.00 10.16 2.55 5.10 6.70 13.20 1.80 1.00 0.80 3.50 3.19 2.70 5° 4° 10° 5° 5° MAX. 4.70 1.50 3.20 2.90 0.75 1.35 1.75 1.45 1.85 0.75 15.20 10.36 6.90 13.70 2.00 1.20 1.00 3.70 3.39 2.90 ITO-220AB • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • ST4045C STB4045C STF4045C SANGDEST MICROELECTRONICS Technical Data Data Sheet N1447, Rev. A Green Products Marking Diagram: Where XXXXX is YYWWL S T B/F 40 45 C SSG YY WW L ST4045C STB4045C = Device Type = Ultralow VF = Package type = Forward Current (40A) = Reverse Voltage (45V) = Configuration = SSG = Year = Week = Lot Number STF4045C Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package Shipping TO-220AB(Pb-Free) 50pcs / tube STB4045C D²PAK(Pb-Free) 800pcs / reel STF4045C ITO-220AB(Pb-Free) 50pcs / tube ST4045C For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Symbol VRWM Condition - Max. 45 Units V Average Forward Current IF(AV) 50% duty cycle @TC =105 °C rectangular wave form 40 A Peak One Cycle NonRepetitive Surge Current (per leg) IFSM 8.3 ms, half Sine pulse 240 A • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • ST4045C STB4045C STF4045C SANGDEST MICROELECTRONICS Technical Data Data Sheet N1447, Rev. A Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Reverse Current (per leg) Reverse Current (per leg) * Junction Capacitance (per leg) * Symbol VF1 VF2 VF3 VF4 VF5 VF6 IR1 IR2 CT Condition @ 5A, Pulse, TJ = 25 °C @ 10A, Pulse, TJ = 25 °C @ 20A, Pulse, TJ = 25 °C @ 5A, Pulse, TJ = 125 °C @ 10A, Pulse, TJ = 125 °C @ 20A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Typ. 0.39 0.43 0.50 0.26 0.31 0.41 Max. 0.47 0.52 0.58 0.35 0.40 0.50 Units V V V V V V 0.21 3.0 mA 116 150 mA 868 - pF Pulse Width < 300µs, Duty Cycle
STF4045C
物料型号: - ST4045C:TO-220AB封装 - STB4045C:D2PAK封装 - STF4045C:ITO-220AB封装
器件简介: 这些是SANGDEST MICROELECTRONICS生产的肖特基整流器,适用于开关电源、转换器、自由轮流通路二极管和反向电池保护。特点包括150°C TJ操作、中心抽头配置、超低正向电压降、高纯度、耐高温环氧封装以增强机械强度和防潮性、高频率操作、保护环以增强坚固性和长期可靠性,且为无铅设备。
引脚分配: - TO-220AB封装有3个引脚。 - D2PAK封装有3个引脚。 - ITO-220AB封装有3个引脚。
参数特性: - 最大反向峰值电压(VRWM):45V - 平均正向电流(IF(AV)):40A(50%占空比,105°C时的矩形波形) - 正向电压降(VF):在不同电流下有不同的典型值,例如5A时为0.39V,10A时为0.43V,20A时为0.50V - 反向电流(IR):在25°C时,额定反向电压下为0.21mA至3.0mA - 结电容(CT):在5V反向电压下,25°C时为868pF
功能详解: 这些肖特基整流器具有超低正向电压降和高结温操作能力,适用于高效率的整流应用。它们还具有较小的结电容,适合高频开关应用。
应用信息: 适用于开关电源、转换器、自由轮流通路二极管和反向电池保护。
封装信息: - ST4045C:TO-220AB封装,每管50pcs - STB4045C:D2PAK封装,每卷800pcs - STF4045C:ITO-220AB封装,每管50pcs
STF4045C 价格&库存
很抱歉,暂时无法提供与“STF4045C”相匹配的价格&库存,您可以联系我们找货
