MBR4045WT
MBR4045WT
    SMCDIODESOLUTIONS(桑德斯)
    TO247
MBR4045WT 数据手册
SANGDEST MICROELECTRONICS MBR4045WT Technical Data Data Sheet N0742, Rev. A Green Products MBR4045WT SCHOTTKY RECTIFIER Applications: • • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Center tap configuration Features: • • • • • • • • • 150°C TJ operation Center tap TO-247AD package Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request ANODE 1 ANODE 2 1 3 2 COMMON CATHODE BASE Mechanical Dimensions: In mm OPTION 1(SR) • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBR4045WT Technical Data Data Sheet N0742, Rev. A Green Products OPTION 2(CJ) TO-247AD • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBR4045WT Technical Data Data Sheet N0742, Rev. A Green Products Marking Diagram: Where XXXXX is YYWWL MBR 40 45 WT SSG YY WW L = Device Type = Forward Current (40A) = Reverse Voltage (45V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device MBR4045WT Package Shipping TO-247AD (Pb-Free) 30pcs/ tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Symbol VRWM Condition - Max. 45 Units V Max. Average Forward IF(AV) IFSM 20(per leg) 40(per device) 318 A Max. Peak One Cycle NonRepetitive Surge Current (per leg) Non-Repetitive Avalanche Energy (per leg) Repetitive Avalanche Current (per leg) 50% duty cycle @TC =125°C, rectangular wave form 8.3 ms, half Sine pulse A 20 mJ 3 A EAS IAR TJ = 25°C, IAS = 3 A, L = 4.40 mH Current decaying linearly to zero in 1 µsec Frequency limited by TJ max. VA = 1.5 x VR typical • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBR4045WT Technical Data Data Sheet N0742, Rev. A Green Products Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * Symbol VF1 VF2 Max. Reverse Current (per leg) * IR1 IR2 IR3 Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change * CT LS dv/dt Condition @ 20A, Pulse, TJ = 25 °C @ 40A, Pulse, TJ = 25 °C @ 20A, Pulse, TJ = 125 °C @ 40A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 100 °C @VR = rated VR TJ = 125 °C @VR = 5 V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Max. 0.70 0.80 0.60 0.75 1.0 Units V V mA 50 mA 85 mA 900 pF 7.5 nH 10,000 V/μs Specification -55 to +150 -55 to +175 Units °C °C 1.4 °C/W 0.7 °C/W 6 g Pulse Width < 300µs, Duty Cycle
MBR4045WT 价格&库存
很抱歉,暂时无法提供与“MBR4045WT”相匹配的价格&库存,您可以联系我们找货
