MBR4060WT
MBR4060WT
    SMCDIODESOLUTIONS(桑德斯)
    TO247
    特性:150℃ TJ 工作。 低正向压降。 高纯度、高温环氧树脂封装,增强机械强度和防潮性。 高频工作。 保护环,增强耐用性和长期可靠性。 这是无铅器件。应用:开关电源。 转换器
MBR4060WT 数据手册
MBR4060WT Technical Data Data Sheet N0741, Rev. A Green Products MBR4060WT SCHOTTKY RECTIFIER Applications: • • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Center tap configuration Features: • • • • • • • • 150°C TJ operation Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request ANODE 1 ANODE 2 1 3 2 COMMON CATHODE BASE Mechanical Dimensions: In mm SYMBOL A A1 A2 b b1 b2 c D D1 D2 E E1 E2 E3 e L L1 P P1 P2 Q S T U MIN. 4.80 2.21 1.90 1.10 0.55 20.80 15.60 19.42 3.50 6.05 OPTION 1(HD) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • TYP. 5.00 2.41 2.00 1.20 2.00 3.00 0.60 21.00 16.55 1.20 15.80 13.30 5.00 2.50 5.44 19.92 4.13 3.60 2.50 5.80 6.15 10.00 6.20 MAX. 5.20 2.61 2.10 1.35 0.75 21.20 16.00 20.42 3.70 7.40 6.25 MBR4060WT Technical Data Data Sheet N0741, Rev. A Green Products OPTION 2(CJ) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR4060WT Technical Data Data Sheet N0741, Rev. A Green Products OPTION 3(SR) TO-247AD • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR4060WT Technical Data Data Sheet N0741, Rev. A Green Products Marking Diagram: Where XXXXX is YYWWL MBR 40 60 WT SSG YY WW L = Device Type = Forward Current (40A) = Reverse Voltage (60V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device MBR4060WT Package Shipping TO-247AD (Pb-Free) 30pcs/ tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current (per device) Peak One Cycle Non-Repetitive Surge Current (per leg) Symbol VRRM VRWM VR Condition - Max. 60 Units V IF (AV) 50% duty cycle @TC = 120°C, rectangular wave form 40 A IFSM 8.3 ms, half Sine pulse 400 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR4060WT Technical Data Data Sheet N0741, Rev. A Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Reverse Current (per leg) * Symbol VF1 VF2 IR1 IR2 Junction Capacitance (per leg) Voltage Rate of Change * CT dv/dt Condition @ 20A, Pulse, TJ = 25 °C @ 20A, Pulse, TJ = 125 °C @VR = rated VR Pulse TJ = 25 °C @VR = rated VR , Pulse TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz - Typ. 0.65 0.62 0.1 Max. 0.75 0.65 1.0 Units V V mA 28 75 mA 400 900 pF - 10,000 V/μs Pulse Width < 300µs, Duty Cycle
MBR4060WT 价格&库存
很抱歉,暂时无法提供与“MBR4060WT”相匹配的价格&库存,您可以联系我们找货
MBR4060WT
    • 1+25.385811+3.27681
    • 25+13.9635925+1.80243
    • 100+11.22742100+1.44924
    • 500+9.03098500+1.16572
    • 1000+8.325181000+1.07462
    • 2000+7.731742000+0.99802
    • 5000+7.089945000+0.91517
    • 10000+6.8540510000+0.88473
    库存:3296
