MBR30200WT
MBR30200WT
    SMCDIODESOLUTIONS(桑德斯)
    TO247
MBR30200WT 数据手册
MBR30200WT Technical Data Data Sheet N0770, Rev. A Green Products MBR30200WT SCHOTTKY RECTIFIER Applications: • • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Center tap configuration Features: • • • • • • • • 150 °C TJ operation Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request ANODE 1 ANODE 2 1 3 2 COMMON CATHODE BASE Mechanical Dimensions: In mm SYMBOL A A1 A2 b b1 b2 c D D1 D2 E E1 E2 E3 e L L1 P P1 P2 Q S T U MIN. 4.80 2.21 1.90 1.10 0.55 20.80 15.60 19.42 3.50 6.05 OPTION 1(HD) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • TYP. 5.00 2.41 2.00 1.20 2.00 3.00 0.60 21.00 16.55 1.20 15.80 13.30 5.00 2.50 5.44 19.92 4.13 3.60 2.50 5.80 6.15 10.00 6.20 MAX. 5.20 2.61 2.10 1.35 0.75 21.20 16.00 20.42 3.70 7.40 6.25 MBR30200WT Technical Data Data Sheet N0770, Rev. A Green Products OPTION 2(CJ) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR30200WT Technical Data Data Sheet N0770, Rev. A Green Products OPTION 3(SR) TO-247AD • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR30200WT Technical Data Data Sheet N0770, Rev. A Green Products Marking Diagram: Where XXXXX is YYWWL MBR 30 200 WT SSG YY WW L = Device Type = Forward Current (30A) = Reverse Voltage (200V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device MBR30200WT Package Shipping TO-247AD (Pb-Free) 30pcs/ tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current(per device) Peak One Cycle Non-Repetitive Surge Current(per leg) Symbol VRRM VRWM VR Condition Max. Units - 200 V IF (AV) 50% duty cycle @TC =133°C, rectangular wave form 30 A IFSM 8.3 ms, half Sine pulse 150 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR30200WT Technical Data Data Sheet N0770, Rev. A Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Symbol VF1 VF2 Reverse Current (per leg) * IR1 IR2 Junction Capacitance (per leg) Typical Series Inductance (per leg) Voltage Rate of Change * CT LS dv/dt Condition @ 15A, Pulse, TJ = 25 °C @ 30 A, Pulse, TJ = 25 °C @ 15 A, Pulse, TJ = 125 °C @ 30 A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Typ. 0.84 0.95 0.68 0.83 Max. 0.90 1.05 0.70 0.85 Units 0.00004 1.0 mA 0.05 6.0 mA 200 400 pF 8.0 - nH - 10,000 V/μs Specification -55 to +150 -55 to +150 2.0 Units °C °C °C/W 50 °C/W 0.50 °C/W 6.7 g V V Pulse Width < 300µs, Duty Cycle
MBR30200WT 价格&库存
很抱歉,暂时无法提供与“MBR30200WT”相匹配的价格&库存,您可以联系我们找货
MBR30200WT
  • 1+25.494941+3.31314
  • 25+14.0568825+1.82673
  • 100+11.30475100+1.46908
  • 500+9.09834500+1.18236
  • 1000+8.389181000+1.09020
  • 2000+7.792952000+1.01272
  • 5000+7.148225000+0.92893
  • 10000+6.9237210000+0.89976
