MBR30150WT
MBR30150WT
    SMCDIODESOLUTIONS(桑德斯)
    TO247
    特性:150℃ Tj 工作。 低正向压降。 高纯度、高温环氧树脂封装,增强机械强度和防潮性。 高频操作。 保护环,增强耐用性和长期可靠性。 这是无铅器件。应用:开关电源。 转换器
MBR30150WT 数据手册
SANGDEST MICROELECTRONICS Technical Data Data Sheet N0768, Rev. - MBR30150WT Green Products MBR30150WT SCHOTTKY RECTIFIER Applications: • • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Center tap configuration Features: • • • • • • • • • 150°C TJ operation Center tap TO-247AD package Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request ANODE 1 ANODE 2 1 3 2 COMMON CATHODE BASE Mechanical Dimensions: In mm OPTION 1(MX) • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBR30150WT Technical Data Data Sheet N0768, Rev. - Green Products OPTION 2(CJ) • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBR30150WT Technical Data Data Sheet N0768, Rev. - Green Products OPTION 3(SR) TO-247AD • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBR30150WT Technical Data Data Sheet N0768, Rev. - Green Products Marking Diagram: Where XXXXX is YYWWL MBR 30 150 WT SSG YY WW L = Device Type = Forward Current (30A) = Reverse Voltage (150V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device MBR30150WT Package Shipping TO-247AD (Pb-Free) 30pcs/ tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward Max. Peak One Cycle NonRepetitive Surge Current (per leg) Symbol VRWM IF(AV) IFSM Condition 50% duty cycle @TC = 105°C, rectangular wave form Max. 150 30 Units V A 8.3 ms, half Sine pulse 408 A • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBR30150WT Technical Data Data Sheet N0768, Rev. - Green Products Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * Max. Reverse Current (per leg) * Symbol VF1 VF2 IR1 IR2 Max. Junction Capacitance (per leg) * CT Condition @ 15A, Pulse, TJ = 25 °C @ 15A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Max. 1.00 0.78 0.1 Units V V mA 15.0 mA 340 pF Specification -55 to +150 -55 to +150 2.20(per leg) Units °C °C Pulse Width < 300µs, Duty Cycle
MBR30150WT
物料型号:MBR30150WT 器件简介:肖特基整流器,适用于开关电源、转换器、自由轮整流二极管、反电池保护、中心抽头配置。
引脚分配:ANODE1、ANODE2为阳极,COMMON CATHODE BASE为阴极。
参数特性: - 最大反向工作峰值电压(VRWM):150V - 最大平均正向电流(IF(AV)):30A - 最大正向电压降(VF1):1.00V(在15A,脉冲,T= 25°C条件下) - 最大反向电流(IR1):0.1mA(在VR=额定VR,T=25°C条件下) - 最大结电容(CT):340pF(在VR = 5V,Tc = 25°C,fsIG=1MHz条件下) 功能详解:150°C TJ操作,中心抽头TO-247AD封装,低正向电压降,高纯度、耐高温环氧树脂封装以增强机械强度和防潮性,高频率操作,保护环以增强鲁棒性和长期可靠性。
应用信息:适用于开关电源、转换器、自由轮整流二极管、反电池保护、中心抽头配置。
封装信息:TO-247AD封装,无铅设备,所有SMC部件都可以追溯到晶圆批次。
请注意,以上信息是根据PDF文档内容进行的中文分析,具体应用和操作应参考产品的技术数据手册。
MBR30150WT 价格&库存
很抱歉,暂时无法提供与“MBR30150WT”相匹配的价格&库存,您可以联系我们找货
MBR30150WT
  • 1+26.245231+3.39423
  • 30+14.0375830+1.81544
  • 120+11.34071120+1.46667
  • 510+9.36033510+1.21055
  • 1020+8.636921020+1.11699
  • 2010+8.040702010+1.03989
  • 5010+7.382535010+0.95477
  • 10020+7.1809910020+0.92870
库存:232
