STW40100C
STW40100C
    SMCDIODESOLUTIONS(桑德斯)
    TO247
STW40100C 数据手册
STW40100C Green Products Technical Data Data Sheet N1516, Rev. - STW40100C SCHOTTKY RECTIFIER Applications:     Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features:          150 °C TJ operation Center tap TO-247AD package Ultralow forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request ANODE 1 3 2 COMMON CATHODE BASE Mechanical Dimensions: In mm/Inches SYMBOL A A1 A2 b b1 b2 c D D1 D2 E E1 E2 E3 e L L1 P P1 P2 Q S T U ANODE 2 1 MIN. 4.80 2.21 1.90 1.10 0.55 20.80 15.60 19.42 3.50 6.05 OPTION 1(HD)  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  TYP. 5.00 2.41 2.00 1.20 2.00 3.00 0.60 21.00 16.55 1.20 15.80 13.30 5.00 2.50 5.44 19.92 4.13 3.60 2.50 5.80 6.15 10.00 6.20 MAX. 5.20 2.61 2.10 1.35 0.75 21.20 16.00 20.42 3.70 7.40 6.25 STW40100C Green Products Technical Data Data Sheet N1516, Rev. - ANODE 1 ANODE 2 1 3 2 COMMON CATHODE BASE OPTION 2(CJ) TO-247AD  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  STW40100C Green Products Technical Data Data Sheet N1516, Rev. - Marking Diagram: Where XXXXX is YYWWL S T W 40 100 C SSG YY WW L = Device Type = Ultralow VF = Package type = Forward Current (40A) = Reverse Voltage (100V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package TO-247AD (Pb-Free) STW40100C Shipping 25pcs / tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current Peak One Cycle Non-Repetitive Surge Current (per leg) Symbol VRRM VRWM VR IF(AV) IFSM Condition - Max. Units 100 V 50% duty cycle @TC =105 C rectangular wave form 40 A 8.3 ms, half Sine pulse 300 A  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  STW40100C Green Products Technical Data Data Sheet N1516, Rev. - Electrical Characteristics: Characteristics Forward Voltage Drop (per leg)* Symbol VF1 VF2 Reverse Current at DC condition (per leg) Reverse Current (per leg) * Junction Capacitance (per leg) Voltage Rate of Change * IR1 IR2 CT dv/dt Condition @ 5A, Pulse, TJ = 25 C @ 10A, Pulse, TJ = 25 C @ 20A, Pulse, TJ = 25 C @ 5A, Pulse, TJ = 125 C @ 10A, Pulse, TJ = 125 C @ 20A, Pulse, TJ = 125 C @VR = 70V,TJ = 25 C @VR = 100V,TJ = 25 C @VR = 70V,TJ = 125 C @VR = 100V,TJ = 125 C @VR = 5V, TC = 25 C fSIG = 1MHz - Typ. 0.47 0.54 0.68 0.38 0.51 0.64 0.012 0.030 10 15 Max. 0.75 0.70 1 75 Units 845 - pF - 10,000 V/s V V mA mA Pulse Width < 300µs, Duty Cycle
STW40100C
物料型号:STW40100C 器件简介:STW40100C 是一款肖特基整流器,适用于开关电源、转换器、自由轮转二极管、反向电池保护等应用。
引脚分配:ANODE 1、ANODE 2 为阳极,COMMON 为阴极基座。
参数特性: - 最大重复反向电压(VRRM):100V - 最大工作峰值反向电压(VRWM):100V - 最大直流阻断电压(VR):100V - 平均整流正向电流(IF(AV)):40A - 峰值非重复浪涌电流(IFSM):300A - 正向电压降(VF):在不同电流下分别为0.47V、0.54V、0.68V - 反向电流(IR):在不同电压下分别为0.012mA、0.030mA - 结电容(CT):845pF - 电压变化率(dv/dt):10,000V/μs 功能详解:STW40100C 具有150°C的工作结温,中心抽头的TO-247AD封装,超低正向电压降,高纯度、耐高温环氧树脂封装以增强机械强度和防潮性能,适用于高频操作,带有增强鲁棒性和长期可靠性的保护环。
应用信息:STW40100C 适用于需要高效率和高可靠性的场合,如开关电源和电机驱动。
封装信息:TO-247AD封装,无铅。
以上信息摘自STW40100C的英文技术手册,手册还包含了详细的机械尺寸、最大额定值、电气特性、热机械规格等技术数据。
STW40100C 价格&库存
很抱歉,暂时无法提供与“STW40100C”相匹配的价格&库存,您可以联系我们找货
STW40100C
  • 1+27.747091+3.58846
  • 25+15.3581525+1.98623
  • 100+12.38809100+1.60212
  • 500+10.00768500+1.29427
  • 1000+9.242581000+1.19532
  • 2000+8.599362000+1.11213
  • 5000+7.903925000+1.02219
  • 10000+7.7557410000+1.00303
库存:196
