MBR6060WT
MBR6060WT
    SMCDIODESOLUTIONS(桑德斯)
    TO247
    一对共阴极
MBR6060WT 数据手册
MBR6060WT Technical Data Data Sheet N0747, Rev. - Applications:      Green Products MBR6060WT SCHOTTKY RECTIFIER Switching power supply Converters Free-Wheeling diodes Reverse battery protection Center tap configuration Features:          150C TJ operation Center tap TO-247AD package Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request ANODE 1 ANODE 2 1 3 2 COMMON CATHODE BASE Mechanical Dimensions: In mm/Inches SYMBOL A A1 A2 b b1 b2 c D D1 D2 E E1 E2 E3 e L L1 P P1 P2 Q S T U MIN. 4.80 2.21 1.90 1.10 0.55 20.80 15.60 19.42 3.50 6.05 OPTION 1(HD)  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  TYP. 5.00 2.41 2.00 1.20 2.00 3.00 0.60 21.00 16.55 1.20 15.80 13.30 5.00 2.50 5.44 19.92 4.13 3.60 2.50 5.80 6.15 10.00 6.20 MAX. 5.20 2.61 2.10 1.35 0.75 21.20 16.00 20.42 3.70 7.40 6.25 MBR6060WT Green Products Technical Data Data Sheet N0747, Rev. - ANODE 1 ANODE 2 1 3 2 COMMON CATHODE BASE OPTION 2(CJ)  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  MBR6060WT Green Products Technical Data Data Sheet N0747, Rev. - OPTION 3(SR) TO-247AD  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  MBR6060WT Green Products Technical Data Data Sheet N0747, Rev. - Marking Diagram: Where XXXXX is YYWWL MBR 60 60 WT SSG YY WW L = Device Type = Forward Current (60A) = Reverse Voltage (60V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device MBR6060WT Package Shipping TO-247AD (Pb-Free) 25pcs/ tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current Repetitive Avalanche Current(per leg) Max. Peak One Cycle NonRepetitive Surge Current (per leg) Symbol VRRM VRWM VR IF(AV) Condition Max Units - 60 V 30(per leg) 60(per device) A 6 A 510 A 50% duty cycle @TC =135℃ rectangular wave form IAR Current decaying linearly to zero in 1 μsec Frequency limited by TJ max.VA=1.5×VR typical IFSM 8.3 ms, half Sine pulse  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  MBR6060WT Green Products Technical Data Data Sheet N0747, Rev. - Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Reverse Current (per leg) * Junction Capacitance (per leg) Typical Series Inductance (per leg) Voltage Rate of Change * Pulse Width < 300µs, Duty Cycle
MBR6060WT 价格&库存
很抱歉,暂时无法提供与“MBR6060WT”相匹配的价格&库存,您可以联系我们找货
