30CPQ200
30CPQ200
    SMCDIODESOLUTIONS(桑德斯)
    TO247
    特性:150℃ TJ 工作。 低正向压降。 高纯度、高温环氧树脂封装,增强机械强度和防潮性。 高频工作。 保护环,增强耐用性和长期可靠性。 这是无铅器件。应用:开关电源。 转换器
30CPQ200 数据手册
30CPQ200 Technical Data Data Sheet N0682, Rev. A Applications:     Green Products 30CPQ200 SCHOTTKY RECTIFIER Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features:           150C TJ operation Center tap TO-247AD package Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Green Products in Compliance with the RoHS Directive This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request ANODE 1 ANODE 2 1 3 2 COMMON CATHODE BASE Mechanical Dimensions: In mm/Inches SYMBOL A A1 A2 b b1 b2 c D D1 D2 E E1 E2 E3 e L L1 P P1 P2 Q S T U MIN. 4.80 2.21 1.90 1.10 0.55 20.80 15.60 19.42 3.50 6.05 OPTION 1(HD)  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  TYP. 5.00 2.41 2.00 1.20 2.00 3.00 0.60 21.00 16.55 1.20 15.80 13.30 5.00 2.50 5.44 19.92 4.13 3.60 2.50 5.80 6.15 10.00 6.20 MAX. 5.20 2.61 2.10 1.35 0.75 21.20 16.00 20.42 3.70 7.40 6.25 30CPQ200 Green Products Technical Data Data Sheet N0682, Rev. A ANODE 1 ANODE 2 1 3 2 COMMON CATHODE BASE OPTION 2(CJ) TO-247AD  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  30CPQ200 Green Products Technical Data Data Sheet N0682, Rev. A Marking Diagram: Where XXXXX is YYWWL 30 C PQ 200 SSG YY WW L = Forward Current (30A) = Configuration = Device Type = Reverse Voltage (200V) = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device 30CPQ200 Package Shipping TO-247AD (Pb-Free) 25pcs/ tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Forward Current Peak One Cycle Non-Repetitive Surge Current (peg leg) Symbol VRRM VRWM VR Condition Max. Units - 200 V IF(AV) 50% duty cycle @TC = 95°C, rectangular wave form 30 A IFSM 8.3 ms, half Sine pulse 408 A  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  30CPQ200 Green Products Technical Data Data Sheet N0682, Rev. A Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Reverse Current (per leg) * Symbol VF1 VF2 IR1 IR2 * Junction Capacitance (per leg) Voltage Rate of Change CT dv/dt Condition @ 15A, Pulse, TJ = 25 C @ 15A, Pulse, TJ = 125 C @VR = rated VR TJ = 25 C @VR = rated VR TJ = 125 C @VR = 5V, TC = 25 C fSIG = 1MHz - Max. 1.05 0.83 Units V V 0.1 mA 15 mA 300 pF 10,000 V/s Specification -55 to +150 -55 to +150 Units C C Pulse Width < 300µs, Duty Cycle
30CPQ200
### 物料型号 - 型号:30CPQ200
### 器件简介 - 应用:开关电源、转换器、自由轮流通二极管、反向电池保护 - 特点:150°C TJ操作、中心抽头TO-247AD封装、低正向电压降、高纯度、高温环氧封装以增强机械强度和防潮性能、高频操作、增强的保护环以提高耐用性和长期可靠性、符合RoHS指令的绿色产品、无铅设备、所有SMC零件都可以追溯到晶圆批次、可根据要求提供额外测试
### 引脚分配 - ANODE 1 和 ANODE 2 为阳极 - COMMON CATHODE BASE 为阴极
### 参数特性 - 最大额定值: - 峰值重复反向电压(VRRM):200V - 工作峰值反向电压(VRWM):200V - DC阻断电压(VR):200V - 平均正向电流(IF(AV)):30A(50%占空比@Tc=95°C,矩形波形) - 峰值单周期非重复浪涌电流(IFSM):408A(8.3ms,半正弦脉冲)
- 电气特性: - 正向电压降(VF1):1.05V(15A,脉冲,T = 25°C) - 正向电压降(VF2):0.83V(15A,脉冲,T = 125°C) - 反向电流(IR1):0.1mA(每腿@VR=额定VR T=25°C) - 反向电流(IR2):15mA(每腿@VR=额定VR T=125°C) - 结电容(CT):300pF(每腿@VR=5V,Tc=25°C fsIG=1MHz) - 电压变化率(dv/dt):10,000V/μs
### 功能详解 - 正向特性:描述了在不同电流和温度下的正向电压降。 - 反向特性:描述了在不同反向电压下的反向电流。 - 结电容:描述了在不同反向电压下的结电容。
### 应用信息 - 适用于需要高频率、高可靠性和低正向电压降的应用场合,如开关电源和电池保护。
### 封装信息 - 封装类型:TO-247AD(无铅) - 包装:25pcs/管
30CPQ200 价格&库存
很抱歉,暂时无法提供与“30CPQ200”相匹配的价格&库存,您可以联系我们找货
