MBR40100WT
MBR40100WT
    SMCDIODESOLUTIONS(桑德斯)
    TO247
MBR40100WT 数据手册
MBR40100WT Technical Data Data Sheet N0128, REV. C Green products MBR40100WT SCHOTTKY RECTIFIER Applications: • • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Center tap configuration Features: • • • • • • • • 150 °C TJ operation Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request ANODE 1 ANODE 2 1 3 2 COMMON CATHODE BASE Mechanical Dimensions: In mm SYMBOL A A1 A2 b b1 b2 c D D1 D2 E E1 E2 E3 e L L1 P P1 P2 Q S T U MIN. 4.80 2.21 1.90 1.10 0.55 20.80 15.60 19.42 3.50 6.05 TYP. 5.00 2.41 2.00 1.20 2.00 3.00 0.60 21.00 16.55 1.20 15.80 13.30 5.00 2.50 5.44 19.92 4.13 3.60 2.50 5.80 6.15 10.00 6.20 OPTION 1(HD) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MAX. 5.20 2.61 2.10 1.35 0.75 21.20 16.00 20.42 3.70 7.40 6.25 MBR40100WT Technical Data Data Sheet N0128, REV. C Green products OPTION 2(CJ) TO-247AD • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR40100WT Technical Data Data Sheet N0128, REV. C Green products Marking Diagram: Where XXXXX is YYWWL MBR 40 100 WT SSG YY WW L = Device Type = Forward Current (40A) = Reverse Voltage (100V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device MBR40100WT Package Shipping TO-247AD (Pb-Free) 30pcs/ tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Forward Current (per device) Peak Repetitive Forward Current(per leg) Peak One Cycle Non-Repetitive Surge Current(per leg) Symbol VRRM VRWM VR IF(AV) IFRM IFSM Condition Max. Units - 100 V 40 A 20 A 280 A 50% duty cycle @TC =135℃ rectangular wave form Rated VR square wave, 20KHz TC =135℃ 8.3 ms, half Sine pulse • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR40100WT Technical Data Data Sheet N0128, REV. C Green products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Reverse Current (per leg) * Symbol VF1 VF2 IR1 IR2 Junction Capacitance (per leg) Series Inductance (per leg) Voltage Rate of Change * CT LS dv/dt Condition @ 20A, Pulse, TJ = 25℃ @ 20A, Pulse, TJ = 125℃ @VR = rated VDC TJ = 25℃ @VR = rated VDC TJ = 125℃ @VR = 5V, TC = 25℃ fSIG = 1MHz Measured lead to lead 5 mm from package body - Typ. 0.80 0.70 0.01 Max. 0.88 0.74 1.0 Units V V mA 6 20 mA 380 800 pF 8.0 - nH - 10,000 V/μs Specification -55 to +150 -55 to +150 2.0 Units ℃ ℃ ℃/W 6.7 g Pulse Width < 300µs, Duty Cycle
MBR40100WT
物料型号: - 型号:MBR40100WT
器件简介: - MBR40100WT是一个肖特基整流器,适用于开关电源、转换器、自由轮二极管、反向电池保护和中心抽头配置。特点包括150°C的TJ操作温度、低正向电压降、高纯度、高温环氧封装以增强机械强度和防潮性能、高频率操作、增强的护圈以提高耐用性和长期可靠性。
引脚分配: - ANODE 1和ANODE 2:阳极 - COMMON CATHODE BASE:共阴极
参数特性: - 最大额定值: - 峰值重复反向电压(VRRM):100V - 工作峰值反向电压(VRWM):100V - DC阻断电压(VR):100V - 平均正向电流(IF(AV)):40A(50%占空比,Tc=135°C矩形波形) - 峰值重复正向电流(IFRM):20A(额定VR方波,20kHz,Tc=135°C) - 峰值单周期非重复浪涌电流(IFSM):280A(8.3ms,半正弦脉冲) - 电气特性: - 正向电压降(VF1):0.80V(20A,脉冲,T=25°C) - 反向电流(IR1):0.01mA(额定VDc,T=25°C)
功能详解: - 该二极管适用于需要高效率和高可靠性的场合,例如在电源转换和电池保护中。其低正向电压降有助于减少功率损耗,而高频率操作能力使其适用于高频电路。
应用信息: - 适用于开关电源、转换器、自由轮二极管、反向电池保护和中心抽头配置。
封装信息: - 封装类型:TO-247AD(无铅) - 包装:30pcs/管
MBR40100WT 价格&库存
很抱歉,暂时无法提供与“MBR40100WT”相匹配的价格&库存,您可以联系我们找货
