30CPQ060
30CPQ060
    SMCDIODESOLUTIONS(桑德斯)
    TO247
30CPQ060 数据手册
30CPQ050 30CPQ060 Technical Data Data Sheet N0678, Rev. - Applications:     Green Products 30CPQ050/30CPQ060 SCHOTTKY RECTIFIER Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features:           150 C TJ operation Center tap TO-247AD package Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Green Products in Compliance with the RoHS Directive This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request ANODE 1 ANODE 2 1 3 2 COMMON CATHODE BASE Mechanical Dimensions: In mm SYMBOL A A1 A2 b b1 b2 c D D1 D2 E E1 E2 E3 e L L1 P P1 P2 Q S T U MIN. 4.80 2.21 1.90 1.10 0.55 20.80 15.60 19.42 3.50 6.05 TYP. 5.00 2.41 2.00 1.20 2.00 3.00 0.60 21.00 16.55 1.20 15.80 13.30 5.00 2.50 5.44 19.92 4.13 3.60 2.50 5.80 6.15 10.00 6.20 TO-247AD  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  MAX. 5.20 2.61 2.10 1.35 0.75 21.20 16.00 20.42 3.70 7.40 6.25 30CPQ050 30CPQ060 Green Products Technical Data Data Sheet N0678, Rev. - Marking Diagram: Where XXXXX is YYWWL 30 C PQ 050 SSG YY WW L = Forward Current (30A) = Configuration = Device Type = Reverse Voltage (50V) = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device 30CPQ050 Package Shipping TO-247AD (Pb-Free) 25pcs/ tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Symbol VRRM VRWM VR Condition Max. Units - 50(30CPQ050) 60(30CPQ060) V Average Forward Current IF(AV) 50% duty cycle @TC = 112°C, rectangular wave form 30 A Peak One Cycle Non-Repetitive Surge Current (peg leg) IFSM 8.3 ms, half Sine pulse 315 A  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  30CPQ050 30CPQ060 Green Products Technical Data Data Sheet N0678, Rev. - Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Symbol VF1 VF2 Reverse Current (per leg) * IR1 IR2 * Junction Capacitance (per leg) Typical Series Inductance (per leg) Voltage Rate of Change CT LS dv/dt Condition @ 15A, Pulse, TJ = 25 C @ 30A, Pulse, TJ = 25 C @ 15A, Pulse, TJ = 125 C @ 30A, Pulse, TJ = 125 C @VR = rated VR TJ = 25 C @VR = rated VR TJ = 125 C @VR = 5V, TC = 25 C fSIG = 1MHz Measured lead to lead 5 mm from package body - Max. 0.60 0.80 0.56 0.70 Units 0.8 mA 45 mA 720 pF 7.5 nH 10,000 V/s Specification -55 to +150 -55 to +150 Units C C V V Pulse Width < 300µs, Duty Cycle
30CPQ060
物料型号为30CPQ050和30CPQ060,是肖特基整流器。
器件简介包括150°C TJ操作、中心抽头TO-247AD封装、低正向电压降、高纯度、高温度环氧树脂封装、高频操作、增强型护环以提高鲁棒性和长期可靠性。
引脚分配为两个阳极、一个共阴极。
参数特性包括最大重复反向电压、工作峰值反向电压、直流阻断电压、平均正向电流、峰值非重复浪涌电流等。
功能详解包括正向电压降和反向电流。
应用信息涉及开关电源、转换器、自由轮转二极管、反向电池保护等。
封装信息为TO-247AD,符合RoHS指令的绿色产品,无铅设备。
30CPQ060 价格&库存
很抱歉,暂时无法提供与“30CPQ060”相匹配的价格&库存,您可以联系我们找货
30CPQ060
  • 1+27.659121+3.56313
  • 25+15.3383425+1.97593
  • 100+12.37398100+1.59406
  • 500+9.99663500+1.28780
  • 1000+9.232701000+1.18939
  • 2000+8.590522000+1.10666
  • 5000+7.896085000+1.01720
  • 10000+7.7501910000+0.99841
库存:154
