30CPQ150
30CPQ150
    SMCDIODESOLUTIONS(桑德斯)
    TO247
    特性:150℃ TJ 工作。 低正向压降。 高纯度、高温环氧树脂封装,增强机械强度和防潮性。 高频工作。 保护环,增强耐用性和长期可靠性。 这是无铅器件。应用:开关电源。 转换器
30CPQ150 数据手册
Technical Data Data Sheet N0681, Rev. A Applications:     30CPQ150 Green Products 30CPQ150 SCHOTTKY RECTIFIER Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features:           150C TJ operation Center tap TO-247AD package Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Green Products in Compliance with the RoHS Directive This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm/Inches SYMBOL A A1 A2 b b1 b2 c D D1 D2 E E1 E2 E3 e L L1 P P1 P2 Q S T U OPTION 1(HD) ANODE 1 1 ANODE 2 3 2 COMMON CATHODE BASE MIN. 4.80 2.21 1.90 1.10 0.55 20.80 15.60 19.42 3.50 6.05  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  TYP. 5.00 2.41 2.00 1.20 2.00 3.00 0.60 21.00 16.55 1.20 15.80 13.30 5.00 2.50 5.44 19.92 4.13 3.60 2.50 5.80 6.15 10.00 6.20 MAX. 5.20 2.61 2.10 1.35 0.75 21.20 16.00 20.42 3.70 7.40 6.25 30CPQ150 Green Products Technical Data Data Sheet N0681, Rev. A ANODE 1 1 ANODE 2 3 2 COMMON CATHODE BASE OPTION 2(CJ) TO-247AD  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  30CPQ150 Green Products Technical Data Data Sheet N0681, Rev. A Marking Diagram: Where XXXXX is YYWWL 30 C PQ 150 SSG YY WW L = Forward Current (30A) = Configuration = Device Type = Reverse Voltage (150V) = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package 30CPQ150 TO-247AD (Pb-Free) Shipping 30pcs/ tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Forward Current Peak One Cycle Non-Repetitive Surge Current (peg leg) Symbol VRRM VRWM VR Condition - IF(AV) 50% duty cycle @TC = 145°C, rectangular wave form IFSM 8.3 ms, half Sine pulse Max. Units 30 A 408 A 150  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  V 30CPQ150 Green Products Technical Data Data Sheet N0681, Rev. A Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Reverse Current (per leg) * * Junction Capacitance (per leg) Voltage Rate of Change Pulse Width < 300µs, Duty Cycle
30CPQ150
物料型号:30CPQ150 SCHOTTKY RECTIFIER 器件简介:30CPQ150是一款符合RoHS指令的绿色产品,无铅设备,所有SMC部件都可以追溯到晶圆批次。
它在150°C的结温下工作,采用中心抽头的TO-247AD封装,具有低正向电压降、高纯度、耐高温的环氧树脂封装,增强了机械强度和防潮性能,适用于高频操作,带有增强的护圈,提高了坚固性和长期可靠性。
引脚分配:ANODE 1、ANODE 2为阳极,COMMON CATHODE为公共阴极,BASE为基座。
参数特性:包括但不限于正向电压降、反向电流、结电容、电压变化率等电气特性,以及结温、存储温度、热阻等热机械特性。
功能详解:该器件适用于开关电源、转换器、自由轮转二极管、反向电池保护等应用。
应用信息:适用于开关电源、转换器、自由轮转二极管、反向电池保护等。
封装信息:采用TO-247AD(Pb-Free)封装,每管30个器件。
机械尺寸和最大额定值也在数据表中给出。
请注意,以上信息是根据您提供的PDF文档链接所提取的中文内容概述。
如需更详细的数据或分析,请提供更具体的问题或要求。
30CPQ150 价格&库存
很抱歉,暂时无法提供与“30CPQ150”相匹配的价格&库存,您可以联系我们找货
