MBR120150WT
MBR120150WT
    SMCDIODESOLUTIONS(桑德斯)
    TO247
    电压:150V 电流:60A
MBR120150WT 数据手册
MBR120150WT Technical Data Data Sheet N0113, Rev. A Green Products MBR120150WT SCHOTTKY RECTIFIER Applications: • • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Center tap configuration Features: • • • • • • • • 175°C TJ operation Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request ANODE 1 ANODE 2 1 3 2 COMMON CATHODE BASE Mechanical Dimensions: In mm SYMBOL A A1 A2 b b1 b2 c D D1 D2 E E1 E2 E3 e L L1 P P1 P2 Q S T U MIN. 4.80 2.21 1.90 1.10 0.55 20.80 15.60 19.42 3.50 6.05 OPTION 1(HD) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • TYP. 5.00 2.41 2.00 1.20 2.00 3.00 0.60 21.00 16.55 1.20 15.80 13.30 5.00 2.50 5.44 19.92 4.13 3.60 2.50 5.80 6.15 10.00 6.20 MAX. 5.20 2.61 2.10 1.35 0.75 21.20 16.00 20.42 3.70 7.40 6.25 MBR120150WT Technical Data Data Sheet N0113, Rev. A Green Products OPTION 2(CJ) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR120150WT Technical Data Data Sheet N0113, Rev. A Green Products OPTION 3(SR) TO-247AD • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR120150WT Technical Data Data Sheet N0113, Rev. A Green Products Marking Diagram: Where XXXXX is YYWWL MBR 120 150 WT SSG YY WW L = Device Type = Forward Current (120A) = Reverse Voltage (150V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device MBR120150WT Package Shipping TO-247AD (Pb-Free) 30pcs/ tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current (per device) Peak One Cycle Non-Repetitive Surge Current(per leg) Symbol VRRM VRWM VR IF(AV) IFSM Condition - 50% duty cycle @TC =150°C, rectangular wave form 8.3 ms, half Sine pulse Max. Units 150 V 120 A 860 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR120150WT Technical Data Data Sheet N0113, Rev. A Green Products Electrical Characteristics: Characteristics Forward Voltage Drop(per leg)* Reverse Current (per leg) * Symbol VF1 VF2 IR1 IR2 Junction Capacitance (per leg) Voltage Rate of Change * CT dv/dt Condition @ 60A, Pulse, TJ = 25 °C @ 60A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz - Typ. 0.84 0.75 0.007 Max. 0.95 0.80 2 Units V V mA 0.4 25.0 mA 900 1600 pF - 10,000 V/μs Specification -55 to +175 -55 to +150 0.4 Units °C °C °C/W 6.7 g Pulse Width < 300µs, Duty Cycle
MBR120150WT
物料型号:MBR120150WT 器件简介:肖特基整流器,适用于开关电源、转换器、自由轮流通道、反向电池保护、中心抽头配置。
引脚分配:ANODE 1、ANODE 2为阳极,COMMON CATHODE为阴极。
参数特性:175°C TJ操作,低正向电压降,高纯度、耐高温环氧树脂封装,提高机械强度和防潮性,高频率操作,保护环提高鲁棒性和长期可靠性,无铅设备。
功能详解:正向电压降、反向电流、结电容、电压变化率。
应用信息:用于需要高可靠性的场合,如核能控制、航空航天、交通设备、医疗设备和安全设备。
封装信息:TO-247AD封装,30pcs/管装运。
MBR120150WT 价格&库存
很抱歉,暂时无法提供与“MBR120150WT”相匹配的价格&库存,您可以联系我们找货
MBR120150WT
  • 1+44.675061+5.78699
  • 25+25.5348725+3.30766
  • 100+20.96803100+2.71610
  • 500+17.31087500+2.24237
  • 1000+16.136751000+2.09028
  • 2000+15.150002000+1.96246
  • 5000+14.810535000+1.91849
