MBR80150WT
MBR80150WT
    SMCDIODESOLUTIONS(桑德斯)
    TO247
    一对共阴极
MBR80150WT 数据手册
MBR80150WT Technical Data Data Sheet N1119, Rev. B Green Products MBR80150WT SCHOTTKY RECTIFIER Applications: • • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Center tap configuration Features: • • • • • • • • • 150°C TJ operation Center tap TO-247AD package Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request ANODE 1 ANODE 2 1 3 2 COMMON CATHODE BASE Mechanical Dimensions: In mm/Inches SYMBOL A A1 A2 b b1 b2 c D D1 D2 E E1 E2 E3 e L L1 P P1 P2 Q S T U MIN. 4.80 2.21 1.90 1.10 0.55 20.80 15.60 19.42 3.50 6.05 OPTION 1(HD) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • TYP. 5.00 2.41 2.00 1.20 2.00 3.00 0.60 21.00 16.55 1.20 15.80 13.30 5.00 2.50 5.44 19.92 4.13 3.60 2.50 5.80 6.15 10.00 6.20 MAX. 5.20 2.61 2.10 1.35 0.75 21.20 16.00 20.42 3.70 7.40 6.25 MBR80150WT Technical Data Data Sheet N1119, Rev. B Green Products OPTION 2(CJ) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR80150WT Technical Data Data Sheet N1119, Rev. B Green Products OPTION 3(SR) TO-247AD • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR80150WT Technical Data Data Sheet N1119, Rev. B Green Products Marking Diagram: Where XXXXX is YYWWL MBR 80 150 WT SSG YY WW L = Device Type = Forward Current (80A) = Reverse Voltage (150V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device MBR80150WT Package Shipping TO-247AD (Pb-Free) 30pcs/ tube For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Symbol VRRM VRWM VR Condition - Max. Units V 150 Average Forward Current IF(AV) rectangular d =0.5, @TC =125 °C 80 Peak One Cycle Non-Repetitive Surge Current (per leg) IFSM 8.3 ms, half Sine pulse 900 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • A A MBR80150WT Technical Data Data Sheet N1119, Rev. B Green Products Electrical Characteristics: Characteristics Forward Voltage Drop(per leg)* Reverse Current (per leg) * Symbol VF1 VF2 IR1 IR2 Junction Capacitance (per leg) Voltage Rate of Change * CT dv/dt Condition @ 40A, Pulse, TJ = 25 °C @ 40A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz - Max. 0.90 0.75 2 Units V V mA 40 mA 1800 pF 10,000 V/μs Specification -55 to +150 -55 to +150 0.25 Units °C °C K/W 6.7 g Pulse Width < 300µs, Duty Cycle
MBR80150WT 价格&库存
很抱歉,暂时无法提供与“MBR80150WT”相匹配的价格&库存,您可以联系我们找货
