408CMQ060
408CMQ060
    SMCDIODESOLUTIONS(桑德斯)
    PRM4
408CMQ060 数据手册
SANGDEST MICROELECTRONICS Technical Data Data Sheet N1229, Rev. B 408CMQ060 Green Products 408CMQ060 SCHOTTKY RECTIFIER Applications: ● High current switching power supply ● Plating power supply ● Free-Wheeling diodes ● Reverse battery protection ● Converters ● UPS System ● Welding Features: • • • • • • • • • 150 ℃ TJ operation Center tap module High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Low forward voltage drop High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm/Inches PRM4 (Isolated) MARKING,MOLDING RESIN st nd Marking for 408CMQ060, 1 row SS YYWWL, 2 row 408CMQ060 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL:94V-0 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 408CMQ060 Technical Data Data Sheet N1229, Rev. B Green Products Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward Current Max. Peak One Cycle NonRepetitive Surge Current (per leg) Non-Repetitive Avalanche Energy(peg leg) Repetitive Avalanche Current(peg leg) Symbol VRWM IF(AV) Condition 50% duty cycle @TC =109°C, rectangular wave form IFSM 8.3 ms, half Sine pulse EAS 200 400 Max. 60 per leg per device Units V A 3960 A TJ=25℃,IAS=1A,L=30mH 15 mJ IAR Current decaying linearly to zero in 1 μsec Frequency limited by TJ max. VA=1.5× VR typical 1 A Symbol Condition @ 200A, Pulse, TJ = 25 °C @ 400A, Pulse, TJ = 25 °C @ 200A, Pulse, TJ = 125 °C @ 400A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * VF1 VF2 Max. Reverse Current (per leg) * Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change Insulation Voltage * IR1 IR2 CT LS dv/dt VRMS Max. 0.68 0.83 0.59 0.76 2.2 600 Units V V mA mA 10000 pF 5.0 nH 11,000 1000 V/μs V Specification -55 to +150 -55 to +150 Units °C °C Pulse Width < 300µs, Duty Cycle
408CMQ060
物料型号为408CMQ060,这是一款肖特基整流器。
器件简介: 408CMQ060 是一款适用于高电流开关电源、电镀电源、飞轮二极管、反向电池保护、转换器、UPS系统和焊接等应用的肖特基整流器。
它具有150℃ TJ操作、中心抽头模块、高纯度、高温环氧封装以增强机械强度和防潮性能。
引脚分配: - 阳极1 = 端子1 - 阳极2 = 端子3 - 公共阴极 = 端子2 - 后缀“R”表示极性反转
参数特性: - 峰值反向电压:60V - 最大平均正向电流(每腿):200A - 最大峰值单周期非重复浪涌电流(每腿):3960A - 非重复雪崩能量(每腿):15mJ - 重复雪崩电流(每腿):1A
功能详解: 408CMQ060 具备低正向压降、高频率操作能力,并有增强的护环以提高坚固性和长期可靠性。
这是无铅设备,所有SMC部件都可以追溯到晶圆批次。
应用信息: 该器件适用于高电流开关电源、电镀电源、飞轮二极管、反向电池保护、转换器、UPS系统和焊接等应用。
封装信息: 封装类型为PRM4隔离型,尺寸为81.28mm x 78.74mm x 49.76mm,安装孔为M3 x 0.5mm。
以上信息摘自SMC Sangdest Microelectronics提供的技术数据表,文档编号N1229,修订版B。
408CMQ060 价格&库存
很抱歉,暂时无法提供与“408CMQ060”相匹配的价格&库存,您可以联系我们找货
408CMQ060
    • 1+691.735611+89.52610
