SANGDEST
MICROELECTRONICS
401CNQ… SERIES
Technical Data
Data Sheet N1225, Rev. B
Green Products
401CNQ035/401CNQ040/401CNQ045
SCHOTTKY RECTIFIER
Applications:
● Switching power supply ● Converters ● Free-Wheeling diodes ● Reverse battery protection
Features:
175℃ TJ operation
Center tap module
High purity, high temperature epoxy encapsulation for enhanced mechanical strength and
moisture resistance
Low forward voltage drop
High frequency operation
Guard ring for enhanced ruggedness and long term reliability
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
Mechanical Dimensions: In mm/ Inches
PRM4 (Non-Isolated)
MARKING,MOLDING RESIN
st
nd
Marking for 401CNQ035/040/045, 1 row SS YYWWL, 2 row 401CNQ035/040/045
Where YY is the manufacture year
WW is the manufacture week code
L is the wafer’s Lot Number
Molding resin
Epoxy resin UL:94V-0
• Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113 (86) 25-87123907 •
• FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn •
SANGDEST
MICROELECTRONICS
401CNQ… SERIES
Technical Data
Green Products
Maximum Ratings:
Characteristics
Peak Inverse Voltage
Max. Average Forward
Current
Max. Peak One Cycle NonRepetitive Surge Current
(per leg)
Non-Repetitive Avalanche
Energy(peg leg)
Current(peg leg)
Symbol
VRWM
Condition
IF(AV)
50% duty cycle @TC =116°C,
rectangular wave form
IFSM
8.3 ms, half Sine pulse
4140
A
EAS
TJ=25℃,IAS=40A,L=0.34mH
270
mJ
IAR
Current decaying linearly to
zero in 1 μsec Frequency
limited by TJ max. VA=1.5×
VR typical
40
A
Symbol
Condition
@ 200A, Pulse, TJ = 25 °C
@ 400A, Pulse, TJ = 25 °C
@ 200A, Pulse, TJ = 125 °C
@ 400A, Pulse, TJ = 125 °C
@VR = rated VR TJ = 25 °C
@VR = rated VR TJ = 125 °C
@VR = 5V, TC = 25 °C
fSIG = 1MHz
Measured lead to lead 5 mm
from package body
35
40
45
200
400
Max.
401CNQ035
401CNQ040
401CNQ045
per leg
per device
Units
V
A
Electrical Characteristics:
Characteristics
Max. Forward Voltage Drop
(per leg) *
VF1
VF2
Max. Reverse Current (per
leg) *
Max. Junction Capacitance
(per leg)
Typical Series Inductance
(per leg)
Max. Voltage Rate of Change
Insulation Voltage
IR1
IR2
CT
LS
dv/dt
VRMS
Max.
0.67
0.78
0.56
0.68
Units
V
V
mA
mA
10300
pF
5.0
nH
10,000
1000
V/μs
V
Specification
-55 to +175
-55 to +175
Units
°C
°C
Pulse Width < 300µs, Duty Cycle
很抱歉,暂时无法提供与“401CNQ045”相匹配的价格&库存,您可以联系我们找货
