409CNQ150
409CNQ150
    SMCDIODESOLUTIONS(桑德斯)
    PRM4
409CNQ150 数据手册
SANGDEST MICROELECTRONICS Technical Data Data Sheet N1231, Rev. B 409CNQ… SERIES Green Products 409CNQ135/409CNQ150 SCHOTTKY RECTIFIER Applications: ● High current switching power supply ● Plating power supply ● Free-Wheeling diodes ● Reverse battery protection ● Converters ● UPS System ● Welding Features: • • • • • • • • • 175℃ TJ operation Center tap module High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance Low forward voltage drop High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions: In mm/ Inches PRM4 (Non-Isolated) MARKING,MOLDING RESIN st nd Marking for 409CNQ135/150, 1 row SS YYWWL, 2 row 409CNQ135/150 Where YY is the manufacture year WW is the manufacture week code L is the wafer’s Lot Number Molding resin Epoxy resin UL:94V-0 • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS 409CNQ… SERIES Technical Data Data Sheet N1231, Rev. B Green Products Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward Current Max. Peak One Cycle NonRepetitive Surge Current (per leg) Symbol VRWM Condition - IF(AV) 50% duty cycle @TC =105°C, rectangular wave form IFSM 8.3 ms, half Sine pulse 135 150 200 400 Max. 409CNQ135 409CNQ150 per leg per device 2760 Units V A A Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg) * Symbol VF1 VF2 Max. Reverse Current (per leg) * Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change * IR1 IR2 CT LS dv/dt Condition @ 200A, Pulse, TJ = 25 °C @ 400A, Pulse, TJ = 25 °C @ 200A, Pulse, TJ = 125 °C @ 400A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Max. 1.03 1.21 0.72 0.83 6 85 Units V V mA mA 6000 pF 5.0 nH 10,000 V/μs Specification -55 to +175 -55 to +175 Units °C °C Pulse Width < 300µs, Duty Cycle
409CNQ150 价格&库存
很抱歉,暂时无法提供与“409CNQ150”相匹配的价格&库存,您可以联系我们找货
409CNQ150
  • 1+690.187861+89.46149
  • 18+511.9741018+66.36159
库存:78
