MBRB3045CTTR
MBRB3045CTTR
    SMCDIODESOLUTIONS(桑德斯)
    TO-263(D²Pak)
    Diode Array 1 Pair Common Cathode Schottky 45V Surface Mount TO-263-3, D²Pak (2 Leads + Tab), TO-26...
MBRB3045CTTR 数据手册
MBRB3045CT Technical Data Data Sheet N0789, Rev. B Green Products MBRB3045CT SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • • 200℃ TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Pure tin plated, solderable per MIL-STD-750, Method 2026 This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions (In mm): Symbol A A1 A2 b b1 c c1 D D1 E E1 E2 e H L L1 L2 L3 e e1 e2 e3 Dimensions in millimeters Min. Typical Max. 4.55 0 2.59 0.71 0.36 1.17 8.55 6.40 10.01 7.6 9.98 14.6 2.00 1.17 0 OPTION 1(HD) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 4.70 0.10 2.69 0.81 1.27 0.38 1.27 8.70 0.61 1.37 8.85 10.16 10.31 10.08 2.54 15.1 2.30 1.27 10.18 0.25BSC 5° 4° 4° 4.85 0.25 2.89 0.96 15.6 2.70 1.40 2.20 8° MBRB3045CT Technical Data Data Sheet N0789, Rev. B Green Products OPTION 2(MX) • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRB3045CT Technical Data Data Sheet N0789, Rev. B Green Products OPTION 3(CJ) D²PAK • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBRB3045CT Technical Data Data Sheet N0789, Rev. B Green Products Marking Diagram: Where XXXXX is YYWWL MBR B 30 45 CT SSG YY WW L = Device Type = Package type = Forward Current (30A) = Reverse Voltage (45V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package D²PAK (Pb-Free) MBRB3045CT Shipping 800pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current Peak One Cycle Non-Repetitive Surge Current (per leg) Symbol VRRM VRWM VR IF (AV) IFSM Condition - Max. 45 Units 50% duty cycle @TC =123 °C, rectangular wave form 8.3 ms, half Sine pulse 15(per leg) 30(per device) 240 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • A MBRB3045CT Technical Data Data Sheet N0789, Rev. B Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Reverse Current (per leg) * Symbol VF1 VF2 IR1 IR2 Junction Capacitance (per leg) Series Inductance (per leg) Voltage Rate of Change * CT LS dv/dt Condition @ 15 A, Pulse, TJ = 25 °C @ 15 A, Pulse, TJ = 125 °C @VR = rated VR TC = 25 °C @VR = rated VR TC = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Typ. 0.60 0.56 Max. 0.65 0.62 Units V V 0.06 0.2 mA 20 40 mA 300 800 pF 8.0 - nH - 10,000 V/μs Units Pulse Width < 300µs, Duty Cycle
MBRB3045CTTR 价格&库存
很抱歉,暂时无法提供与“MBRB3045CTTR”相匹配的价格&库存,您可以联系我们找货
