MBRB40200CTTR
MBRB40200CTTR
    SMCDIODESOLUTIONS(桑德斯)
    TO-263(D²Pak)
    DIODEARRAYSCHOTTKY200VD2PAK
MBRB40200CTTR 数据手册
SANGDEST MICROELECTRONICS MBRB40200CT Technical Data Data Sheet N0793, Rev. - Green Products MBRB40200CT SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150℃ TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Dimensions (In Inches / mm): Symbol A A1 A2 b b1 c c1 D D1 E E1 E2 e H L L1 L2 L3 e e1 e2 e3 Dimensions in millimeters Min. Typical Max. 4.55 0 2.59 0.71 0.36 1.17 8.55 6.40 10.01 7.6 9.98 14.6 2.00 1.17 0 4.70 0.10 2.69 0.81 1.27 0.38 1.27 8.70 4.85 0.25 2.89 0.96 0.61 1.37 8.85 10.16 10.31 10.08 2.54 15.1 2.30 1.27 10.18 15.6 2.70 1.40 2.20 0.25BSC 5° 4° 4° 8° OPTION 1(HD) • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRB40200CT Technical Data Data Sheet N0793, Rev. - Green Products OPTION 2(MX) • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRB40200CT Technical Data Data Sheet N0793, Rev. - Green Products OPTION 3(CJ) D²PAK • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRB40200CT Technical Data Data Sheet N0793, Rev. - Green Products Marking Diagram: Where XXXXX is YYWWL MBR B 40 200 CT SSG YY WW L = Device Type = Package type = Forward Current (40A) = Reverse Voltage (200V) = Configuration = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package D²PAK (Pb-Free) MBRB40200CT Shipping 800pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Max. Average Forward Max. Peak One Cycle NonRepetitive Surge Current (per leg) Symbol VRWM IF(AV) IFSM Condition 50% duty cycle @TC =110°C, rectangular wave form 8.3 ms, half Sine pulse Max. 200 20(per leg) 40(Per device) 396 Units V A A • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • SANGDEST MICROELECTRONICS MBRB40200CT Technical Data Data Sheet N0793, Rev. - Green Products Electrical Characteristics: Characteristics Max. Forward Voltage Drop (per leg)* Max. Reverse Current at DC condition (per leg) Max. Reverse Current (per leg)* Max. Junction Capacitance (per leg) Typical Series Inductance (per leg) Max. Voltage Rate of Change * Symbol VF1 VF2 IR1 IR2 CT LS dv/dt Condition @ 20A, Pulse, TJ = 25 °C @ 20 A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Measured lead to lead 5 mm from package body - Max. 0.90 0.80 1.0 Units V V mA 11.0 mA 450 pF 8.0 nH 10,000 V/μs Specification -55 to +150 -55 to +150 2.0 Units °C °C °C/W 1.85 g Pulse Width < 300µs, Duty Cycle
MBRB40200CTTR
物料型号:MBRB40200CT 器件简介:肖特基整流器,适用于开关电源、转换器、自由轮流通路二极管、反向电池保护。
引脚分配:中心抽头配置。
参数特性:150℃ TJ操作,低正向电压降,高纯度、耐高温环氧封装,高频率操作,保护环增强鲁棒性和长期可靠性,无铅设备,所有SMC部件可追溯至晶圆批次。
功能详解:提供高效率的整流功能,低功耗,高可靠性,适用于高频应用。
应用信息:适用于需要高效率和高可靠性整流器的场合,如开关电源和电池保护。
封装信息:D2PAK封装,800pcs/卷轴包装。
最大结温150℃,最大储存温度150℃,最大热阻抗2.0℃/W,重量约1.85g。
MBRB40200CTTR 价格&库存
很抱歉,暂时无法提供与“MBRB40200CTTR”相匹配的价格&库存,您可以联系我们找货
