STB60100CTR
STB60100CTR
    SMCDIODESOLUTIONS(桑德斯)
    TO-263(D²Pak)
    Diode Array 1 Pair Common Cathode Schottky 100V Surface Mount TO-263-3, D²Pak (2 Leads + Tab), TO-2...
STB60100CTR 数据手册
ST60100C STB60100C STF60100C SANGDEST MICROELECTRONICS Technical Data Data Sheet N1505, Rev. - Green Products ST60100C STB60100C STF60100C SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150 °C TJ operation Center tap configuration Ultralow forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request ST60100C TO-220AB OUTLINE DRAWING Case styles STB60100C STF60100C D2PAK ITO-220AB Mechanical Dimensions: In Inches / mm TO-220AB • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • ST60100C STB60100C STF60100C SANGDEST MICROELECTRONICS Technical Data Data Sheet N1505, Rev. - Green Products Symbol A A1 A2 b b1 c c1 D D1 E E1 E2 e H L L1 L2 L3 e e1 e2 e3 Dimensions in millimeters Min. Typical Max. 4.55 0 2.59 0.71 0.36 1.17 8.55 6.40 10.01 7.6 9.98 14.6 2.00 1.17 0 4.70 0.10 2.69 0.81 1.27 0.38 1.27 8.70 0.61 1.37 8.85 10.16 10.31 10.08 2.54 15.1 2.30 1.27 10.18 0.25BSC 5° 4° 4° 4.85 0.25 2.89 0.96 15.6 2.70 1.40 2.20 8° D2PAK • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • ST60100C STB60100C STF60100C SANGDEST MICROELECTRONICS Technical Data Data Sheet N1505, Rev. - Green Products SYMBOL A A1 A2 A3 b b1 b2 b3 b4 c D E e e1 H1 L L1 L2 L3 ΦP1(上口) ΦP2(下口) Q Θ1 Θ2 Θ3 Θ4 Θ5 MIN. 4.30 1.10 2.80 2.50 0.50 1.10 1.50 1.20 1.60 0.55 14.80 9.96 6.50 12.70 1.60 0.80 0.60 3.30 2.99 2.50 TYP. 4.50 1.30 3.00 2.70 0.60 1.20 1.60 1.30 1.70 0.60 15.00 10.16 2.55 5.10 6.70 13.20 1.80 1.00 0.80 3.50 3.19 2.70 5° 4° 10° 5° 5° MAX. 4.70 1.50 3.20 2.90 0.75 1.35 1.75 1.45 1.85 0.75 15.20 10.36 6.90 13.70 2.00 1.20 1.00 3.70 3.39 2.90 ITO-220AB • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • ST60100C STB60100C STF60100C SANGDEST MICROELECTRONICS Technical Data Data Sheet N1505, Rev. - Green Products Marking Diagram: Where XXXXX is YYWWL S T B/F 60 100 C SSG YY WW L ST60100C STB60100C = Device Type = Ultralow VF = Package type = Forward Current (60A) = Reverse Voltage (100V) = Configuration = SSG = Year = Week = Lot Number STF60100C Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package Shipping TO-220AB(Pb-Free) 50pcs / tube STB60100C D²PAK(Pb-Free) 800pcs / reel STF60100C ITO-220AB(Pb-Free) 50pcs / tube ST60100C For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Symbol VRWM Condition - Max. 100 Units V Average Forward Current IF(AV) 50% duty cycle @TC =105 °C rectangular wave form 60 A Peak One Cycle NonRepetitive Surge Current (per leg) IFSM 8.3 ms, half Sine pulse 300 A • Weiqi Street, Airport Development Zone, Jiangning District, Nanjing, China 211113  (86) 25-87123907 • • FAX (86) 25-87123900 • World Wide Web Site - http://www.sangdest.com.cn • E-Mail Address - sales@ sangdest.com.cn • ST60100C STB60100C STF60100C SANGDEST MICROELECTRONICS Technical Data Data Sheet N1505, Rev. - Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg)* Symbol VF1 VF2 Reverse Current at DC condition (per leg) Reverse Current (per leg) * Junction Capacitance (per leg) * IR1 IR2 CT Condition @ 5A, Pulse, TJ = 25 °C @ 10A, Pulse, TJ = 25 °C @ 15A, Pulse, TJ = 25 °C @ 20A, Pulse, TJ = 25 °C @ 30A, Pulse, TJ = 25 °C @ 5A, Pulse, TJ = 125 °C @ 10A, Pulse, TJ = 125 °C @ 15A, Pulse, TJ = 125 °C @ 20A, Pulse, TJ = 125 °C @ 30A, Pulse, TJ = 125 °C @VR = 70V,TJ = 25 °C @VR = 100V,TJ = 25 °C @VR = 70V,TJ = 125 °C @VR = 100V,TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz Typ. 0.47 0.54 0.61 0.68 0.82 0.38 0.51 0.58 0.64 0.74 Max. 0.68 0.90 0.012 0.030 10 15 1 75 845 - 0.65 0.80 Units V V mA mA pF Pulse Width < 300µs, Duty Cycle
STB60100CTR
物料型号: - ST60100C:TO-220AB封装 - STB60100C:D2PAK封装 - STF60100C:ITO-220AB封装
器件简介: 这些肖特基整流器适用于开关电源、转换器、自由轮流通道二极管和反向电池保护。特点包括150°C TJ操作、中心抽头配置、超低正向电压降、高纯度、耐高温环氧封装以增强机械强度和防潮性、高频率操作、防护环以增强耐用性和长期可靠性。这些设备都是无铅的,所有SMC零件都可以追溯到晶圆批次。
引脚分配: - ST60100C(TO-220AB):3个引脚 - STB60100C(D2PAK):2个引脚 - STF60100C(ITO-220AB):3个引脚
参数特性: - 最大反向峰值电压(VRWM):100V - 平均正向电流(IF(AV)):60A(50%占空比,105°C时的矩形波形) - 正向电压降(VF1):5A时0.47V,10A时0.54V,15A时0.61V,20A时0.68V,30A时0.82V - 反向电流(IR1):在70V时0.012mA,100V时0.030mA
功能详解: 这些肖特基整流器适用于需要高效率和高可靠性的应用场合。它们能够处理高达60A的正向电流和高达100V的反向电压。超低正向电压降有助于减少功率损耗,而高频率操作能力使其适用于高速开关应用。
应用信息: 适用于开关电源、转换器、自由轮流通道二极管和反向电池保护。
封装信息: - ST60100C:TO-220AB(Pb-Free),50pcs/管 - STB60100C:D2PAK(Pb-Free),800pcs/卷 - STF60100C:ITO-220AB(Pb-Free),50pcs/管
STB60100CTR 价格&库存
很抱歉,暂时无法提供与“STB60100CTR”相匹配的价格&库存,您可以联系我们找货
