Cetus International Ltd.
SINGLE RJ45 CONNECTOR MODULE WITH 10/100 BASE-TX
MAGNETICS AND LEDS
P/N: J1B121
J1B12111CCD
Page : 1/3
Feature
Suitable for CAT 5 & 6 Fast Ethernet Cable or better UTP.
Meets or exceeds IEEE 802.3 standard for 100 Base-T.
350 µH minimum OCL with 8 mA bias current.
Minimum 1500 Vrms isolation per IEEE 802.3 requirement.
All materials are RoHS and UL94-V0 compliant.
RoHS peak solder rating 260°C.
Meet EN60950-1 basic insulation requirement.
Recommended panel.
Part Number
9,10 (Left Led)
11,12 (Right Led)
2
Green
Yellow
Electrical Specifications @ 25
25°°C
Turns Ratio
(±5%)
Part
Number
J1B1211CCD
Insertion Loss
(dB Max)
Return Loss
100ohm±5ohm (dB Min)
TX
RX
1-100MHz
1-30MHz
30-60MHz
60-80MHz
1CT:1CT
1CT:1CT
-1.0
-18
-14
-12
25°°C
Part
Number
Crosstalk
(dB Min)
Common Mode Rejection
(dB Min)
HI-POT
(Vac)
1-100MHz
1-100MHz
@60s
-30
-30
1500
J1B1211CCD
RJ45 Durability Testing Rating & Material Specification
Part
Number
Durability
Mating Force
J1B1211CCD
750 Insertions
5 lbs./2.268 kgs.
Shield
Material
Finish
Brass
30µ inches Nickel over
RJ45 Material Specification
Part
Number
J1B1211CCD
Contact
Housing
Material
Plating Area
Material
Specification
Phosphor
Brass
50µ inches Nickel over
selective gold plating 6µ inches
Thermoplastic
UL 94 V-0
* Operating temperature range: -40℃ to +85℃. Storage temperature range: -20℃ to +125℃.
757-81811611
Tel:+86Tel:+86-757-81811611
E-mail:sales@ceetus.com.cn
757-81811621
Fax:+86Fax:+86-757-81811621
Websit
e
:www.ceetus.com.cn
Website
V0
MAGNETICS AND LEDS
P/N: J1B121
J1B12111CCD
Page : 2/3
Schematic
Mechanical
Units: mm.
Tolerance: ±0.25 unless specified.
757-81811611
757-81811621
Websit
e
:www.ceetus.com.cn
Website
V0
MAGNETICS AND LEDS
P/N: J1B121
J1B12111CCD
Page : 3/3
PCB Layout Mounting Hole (Top View)
757-81811611
757-81811621
Websit
e
:www.ceetus.com.cn
Website
V0
很抱歉,暂时无法提供与“J1B1211CCD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+16.86960
- 10+14.48370
- 24+12.98880
- 48+12.79397
- 120+10.93950
- 1200+10.83010
